LabVIEW Embedded
LM3S8962_I2C_RW_AT24C02 EEPROM
LabVIEW for ARM V8.6
The address 0 EEPROM page datas are why did not modify?
Message 1 of 8
(10,316 Views)
Try this snippet (or redraw your diagram in 8.6)
Message 2 of 8
(10,289 Views)
Thank you for answering!
I wrote a program in accordance with the picture, but running, reading back the data is 0xFF, do not know AT24C02 chip is broken?  tomorrow to buy chips, then a response ... ...
Message 3 of 8
(10,283 Views)
EEPROM chip replacement, and test did not succeed, the result value is 255?
Message 4 of 8
(10,258 Views)
Have not run well in the I2C example? Today connected to the clock chip DS1307, during the debugging, the data to write and read  is also wrong. . .
Message 5 of 8
(10,241 Views)
Here is my running for the AT24C02 chip program results, in the front panel the Read Data does not display the results? Always gray state.
Message 6 of 8
(10,219 Views)
I observed with the oscilloscope on the signal waveform SCL and SDA. This two signal lines up-pulled 10K resistor. No run-time waveform created?
Message 7 of 8
(10,174 Views)
Accepted by mcusir
Hi, read and write on the AT24C02 chip finally succeeded! Chip address only low 7bits effective. Do not add read and write bits.
Message 8 of 8
(10,116 Views)
