nottilie
Easy change from Propery Node to Invoke Node
Status: New
Dear community and developers
I would have the suggestion to add a simple context menu enty on property nodes and on invoke nodes.
Just add in invoke nodes the menu entry (Change to property node) and
on property nodes add an etry (Change to invoke node).
I often have to change this and this would help to improve the work flow for me.
Gernot Hanel
IONICON Analytik Gesellschaft m.b.H.
www.ionicon.com
Gernot Hanel
6 Comments
fabric
Active Participant
Yes! Excellent idea.
(Good candidate for a shortcut menu plugin)
fabric
Active Participant
Ok - I anyway needed some practice writing plugins...
Do these satisfy your idea?
Darren
Proven Zealot
Don't forget about using Quick Drop to accelerate editor tasks like this. I do a lot of VI Server programming, so I need this replace operation all the time (sometimes on multiple nodes at once). Here's how I do it:
Select Property Node(s) -> Ctrl-Space -> 'nv' -> Ctrl-P
'nv' is my object shortcut for Invoke Node. Ctrl-P is the keyboard shortcut for Replace.  The same approach works for replacing Invoke Nodes with Property Nodes, just with 'rn', which is my object shortcut for Property Node.
bienieck
Active Participant
I also use Darrens approach and recommend this for You nottile 😉
BTW it will be cool to have this QD "aliases" by default in LV. This way it could become some kind of standard.
Aliases list can be found here: https://decibel.ni.com/content/docs/DOC-8344
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
Darren
Proven Zealot
bienieck, I am planning on shipping a set of default object shortcuts in LabVIEW 2016. Check out the discussion here:
https://decibel.ni.com/content/message/115479
nottilie
Thank you for the quick drop and replace approach.
I also use this option but never had the idea to use it in this context.
I also will check out the menu plugin.
Gernot Hanel
