6 | |
5 | |
2 | |
2 | |
2 |
It would be great to be able to search on network shared varaibles to find where all they are used within your code and if they are read or write same as local variables. When the feature came out that identified if it was a read or write within the search window, this was great because it was easy to know if you had too many writes. The only way I know of at this time to search on a shared variable is to search on the text. Thanks for listening.
