6 | |
5 | |
2 | |
2 | |
2 |
Hi All,
i think it would be useful to have one VI which can check path constants whether they contains invalid characters or not.
A lot of VIs doing some file operations returns errors if the file contains invalid characters but it should be checked before calling the VI with the file operations.
I found the `Is Name Multiplatform VI` which can check it, but it is hard to find that this VI will solve this question, accepts strings as input instead of paths, and also it has a lot of unnecessary in and outputs.
I think it would be would be more useful if there would be a simple VI with just one path input and one boolean output to check the path against the current platform.
What do you think about it?
