6 | |
6 | |
3 | |
2 | |
2 |
I believe many of you had already the problem that you accidentally changed a VI's from the vi.lib and saved it.
There should be an option to use the complete vi.lib Read only!
I do not want to change the VI's in the vi.lib at all! Never!
Thanks for your support.
Excuse for my bad English.
Sample of an open VI from the vi.lib
and in the Options Menu it can look like this:
