It would be great to determine properties of a disk drive i.e. type and size. There have been a number of my applications that would benefit from knowing the difference between a local drive and a network drive. Drive Types are shown below.
It is simple in LabVIEW to get a list of disk drives on a given computer as shown:
There are round about ways to get drive information such as command prompt and the system exec.vi and registry vi’s. These methods require a lot of overhead and programming. There is currently no simple function in LabVIEW that I can find that will return the properties of a disk drive.
This idea is more of a request for National Instruments to include a new VI that will get Properties of a Disk Drive. This new VI should be similar to the existing Get File Info VIs.
