Community Browser
Post an idea
Since a few days I'm struggling to debug a packaged library. The project library works when called with development system. If called by the corresponding executable I’m only getting error 1498 and there is no way (to my knowledge) to obtain more/usefull information. Even inside the LVInternalReports folder no information is stored. REALLY useful as well would be the bugfix of CARS #684847 which is reported since version 2016, which prevents to show the block diagram of nested PPL if called from the executable…
So please give a more convenient way to debug packed libraries and fix the mentioned CARS.
Today, a for loop always select the minimum number of iteration between the number wired in "N" input and the size of every auto-indexed array.
It will be great to select between three mode :
- the minimum value, like today, with a "N" terminal.
- a fix value, ie the value send to the terminal, who become a "F" terminal (for example), no mater the size of the auto-indexed array.
- the maximum value, with a "M" terminal for example.
When you select a directory for logging data on signal express, it would be useful to see an error prompt or an warning prompt to prevent over-writing and/or loss of data.
With use Conditional Disable Structure developer define custom Conditional Disable Symbols as Project property.
I think, add option to define Conditional Disable Symbols as Labview property.
Now I use Project code in two computers with different MS Office versions (2013 and 2016).
Because part of Office functions in different versions has different count of parameters (example, Save As), I must replace Invoke mode each time open my project in other PC
I'm working on a high-performance application where every bit of time counts.
LabVIEW's parallel execution helps but we are having to write individual functions in C so we can try out the AVX instructions available on modern processors.
LabVIEW recently used SSE2 so I guess the compiler supports this (well, LLVM certainly does). It would be good to have an advanced option to enable more recent updates (AVX+) to avoid going to C!
The close reference node returns errors for invalid references (1026, 1055 etc.). The majority of the time, I don't really care. I then have to manually filter out this error on that particular node.
Could we have a bollean option to generate warnings on invalid VI refs instead? Similar to the following:
Whenever we add a new item in tree programatically using "edit tree item" node,
We are not sure what tag would be set to Child Tag. Because if that tag already exists LabVIEW will appends a number to make it unique.
From help of "Edit Tree Items:Add Item Method"
The default is the string you wire to Left Cell String. If an existing tag already uses that string, LabVIEW appends a number to the string to create a unique tag for the new item.
It would be great if we can get the value of "Child Tag" as output as well, which is set by LabVIEW.
When developing a Complex LabVIEW Applications, we may need to create N Number of Folders as a part of Configuration information.
This requires the developer to make a check "Check if File or Folder Exists"
Instead of that Create Folder Function can have a Boolean "Optional Input" to create the Folder only if not found in the specified Location and Eliminating the Error when trying to create same folder again.
Hope this will help Smiley Happy
The error cluster is obsolete, it's time to move on. It's 2018 we need a more flexible error output.
it's deeply hard-coded into LV.
The most hard-coded thing that is impossible to remove is that it's used as a way to force sequential instructions (error in -> error out are many times the only connectors).
The problem is that
  • the error codes are limited
  • dont scale.
  • cant embed additional object into it.
I can't use the full range of I32 as error code.
If I use error code 6400, it will clash into yours 6400 custom code.
I need a way to say : this is the error code of MyModule/Actor/class/LVLIB, that I need to "namespace" error codes
I need an additional object into error cluster, so I can carry more info.
So pls NI, empower error cluster with additional field: "meta error object", that we can derive/extend and use.
When creating a LabVIEW installer, in the Source File Settings dialog, I might change the attributes of several files in the same way.  For example, I might make many files read-only and/or hidden.  Currently, I have to click on each file and change its attributes.  I would like to be able to choose multiple files (either by highlight, control-click, etc.) and change their attributes at the same time to the same setting.
Pulido Technologies LLC
The ability to define anonymous methods to be called multiple times within a block diagram.Capture.PNG
When passing a control reference to a sub vi , it would be nice to be able to map ALL properties to the taget control in one hit rather than individually setting each property in turn from the reference.
This is something that started as a way to get data back from Actors in non-actor code (for example, web services). I've never cared for the blocking nature of Reply Msgs and the only other built-in option for getting back data is to make everything an Actor, which is not always an option. Promises solve both of those issues.
The basic idea is an enforced single-writer, many-reader cross thread datatype. In the current implementation, they are not much more than a locked-down, single element queue but you can actually do some pretty cool stuff with just that.
In the message sender, we create the promise and return it. The idea here is that the Actor owns the promise and will fulfill it. This gives us very low coupling for free.
Actor_Example_lvlib_Start_Long_Running_Process_Msg_lvclass_Send_Start_Long_Running_Processd.png
Wait on Promise will wait for the Promise to be fulfilled. It is a malleable VI so that a Default Value (for timeout) and Type can be wired. Using the timeout lets us do other things while waiting for data.
Inside the Actor, we can set the value with Fulfill Promise. Remember, once the Promise is set, that's it, no changing it again. In fact, Fulfill Promise will error out if called twice on the same promise.
Something else really cool we can do is fulfill a promise with another promise. This may seem pedantic at first but it can help keep your code cohesive by passing the responsibility of fulfilling a Promise to another process. For example, if you have a message broker that just forwards a message, you can have the message broker fulfill it's promise to the caller with a promise from the callee.
We can also reject a promise with an error message that will be returned by any Wait on Promise that tries to read it. Rejecting a promise does fulfill the promise so you still cannot set the value later and you cannot reject a promise again.
Finally, we have Destroy Promise. It does exactly what it says on the tin.
I'd love to hit some more of the design points from https://promisesaplus.com/ (mainly adding Then callbacks) but I figure it's at a pretty good spot to share and get some feedback. I'd also like to try to figure out network communication at some point but that's probably a ways away (without some help anyway Smiley Wink).
I'm hosting the code at https://github.com/kgullion/LabVIEW-Promise if you are interested in checking it out or contributing!
Please provide a setting to exclude unspecified folders.
I started a Mass Compile on one folder. Whoa, it did more than I expected! It changed and saved hundreds of files. I let it run for about a minute, got too nervous, and stopped it. I was surprised that I gave it one folder to recompile and it saved called Vis even if they were in other folders above and outside of the one I had specified. I didn’t think to back those up.
NI's code should be excluded! Many VIs are installed as part of LabVIEW in the C:\Program Files (x86)\National Instruments\LabVIEW folder. These should NEVER be modified outside of installs/upgrades. I started a Mass Compile and, whoa, it did much more than I expected! It changed and saved hundreds of files. I let it run for about a minute, got too nervous, and stopped it. I didn’t think to back that up. Now I fear my LabVIEW installation is dirty. NI SR#7722650 says "It does go outside of the specific folder if the VIs in the specific folder depend on another VI outside of the folder. When it goes outside, it is just opening the VI and resaving it in the current version of LabVIEW. Because your VIs depend on some VIs in the ... vi.lib it went and resaved them. But, they are already in LabVIEW 2015 SP1, so it will not change anything in them. It does this to ensure the VI is looking at the current version of LabVIEW and not an older version." If that is true, why would installation of a version of LabVIEW install VIs of older versions? Make sure all vi.lib VIs are already compiled for that version.
I found https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Force-Recompile-option-in-Mass-Compile/idi-p/2659839 which discusses whether or not LabVIEW Mass Compile changes files that are already up-to-date.
Mass Compile changes files that do not have a LabVIEW code extension such as ".ctl" and ".vi"! Why is it trying to load, check, and save files with extensions such as ".bak" and “.err”? The following example shows files that a prior mass compile found problems with and I renamed them and removed them from source code control.
  ### Bad VI:    "EditString.ctl.err"              Path="C:\cvs\r8000\labview\app\editor\controls\EditString.ctl.err"
  ### Bad VI:    "MCNavigate_old.vi.err" Path="C:\cvs\r8000\labview\app\remote_control\MCNavigate_old.vi.err"
Another example of this is described in https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Mass-Compile-should-not-touch-Subversion-files/idi-p/1081483 which says files with ".svn-base" are changes. Yes, there was a specific improvement made to ignore those, but really, that wouldn't be necessary if Mass Compile stuck to known LabVIEW file types.
We can get the top level VI using property nodes / call chain, and we can also determine the running state of any specific VI (given a path).
It would be really useful to know which VI was running as any point in time (without resorting to execution highlighting) - not really applicable to time critical applications of course.
Uses for this include:
1) the abilty to change a VI execution state from Modal to normal with custom created dropins - if required.
2) Automation - it would be really useful to retrofit projects with a tool/dropin for soak testing / debug which detected certain windows - normally these would be modal dialogs and entered data in them to allow the program to continue (I know these features can be built in at the start of a project, but dropping in later would be very powerful for pre-existing ones and allow the use of the NI dialogs.
3) simple debug - code is stuck, exection highlighting is not showing where. This would give the answer.
James
64bit has been the dominant architecture for a decade; any computer with more than ~2.5GB of RAM must use it after all. It is inevitable that 32-bit machines will cease to be made - maybe not tomorrow, but let's be realistic. Let's get ahead of the times and convert modules to support 64 bit. Please!
Hello R&D,
Further to this message, I'd like to have this feature in LV by way of a VI Server Method.
https://forums.ni.com/t5/LabVIEW-APIs-Discussions/Creating-a-VI-snippet/m-p/3402132#M643
The commands for VI Snippet are not currently exposed through VI Server. One of our LabVIEW Product Managers is investigating the feasibility of releasing a G-code method of creating snippets and delivering this to the community in the form of a right-click framework or quick drop plugin.
-Bob
Partha (CLD, CSP).
Currently there are no officially supported frameworks for Unit Testing in LabVIEW for Linux.
A lack of a unit testing framework on LabVIEW for Linux reduces LabVIEW's usability in widely-recognized and industry standard software engineering practices.
A Unit Test Framework created by NI already exists, as well as a 3rd-party tool for free, VI Tester by JKI. However, neither of these are available for desktop Linux (or Macintosh).
NI LabVIEW Unit Test Framework Toolkit
VI Tester - JKI
https://github.com/JKISoftware/JKI-VI-Tester/wiki
