Community Browser
Post an idea
DVRs are references, and are automatically released when the VI hierarchy that created and "owns" it goes idle (stops executing).  Commonly, the DVR just contains by-value objects, or LabVIEW references that are also automatically released, but an important use case of DVRs is wrapping a non-labview reference that must be properly cleaned-up.   An example is an SQLite Connection pointer that must have a dll method called on it in order to release the database file it is holding open.  Many dlls have similar pointers/handles that need to be properly closed.  This is a headache for Programmers, who cannot rely on a stopped VI releasing its resources, often requiring restarts of LabVIEW to unload the dll.
A clean and easy solution to this problem would be to allow a "DVR Cleanup Callback VI" to be registered with the system when the DVR is created.   That VI would be called if and only if the DVR is release because its calling VI hierarchy goes idle.   This VI would contain the code to cleanup/close the contained non-LabVIEW references.  Could have other uses, such as debugging.
I have developed multiple APIs that wrap non-LabVIEW dlls, and this feature would be a very significant help.   Please consider it.
it would be great if adobe reader was built into the additional installers section of the project installer build.
i would think this would be a common thing users end up installing sperately
This is something that started as a way to get data back from Actors in non-actor code (for example, web services). I've never cared for the blocking nature of Reply Msgs and the only other built-in option for getting back data is to make everything an Actor, which is not always an option. Promises solve both of those issues.
The basic idea is an enforced single-writer, many-reader cross thread datatype. In the current implementation, they are not much more than a locked-down, single element queue but you can actually do some pretty cool stuff with just that.
In the message sender, we create the promise and return it. The idea here is that the Actor owns the promise and will fulfill it. This gives us very low coupling for free.
Actor_Example_lvlib_Start_Long_Running_Process_Msg_lvclass_Send_Start_Long_Running_Processd.png
Wait on Promise will wait for the Promise to be fulfilled. It is a malleable VI so that a Default Value (for timeout) and Type can be wired. Using the timeout lets us do other things while waiting for data.
Inside the Actor, we can set the value with Fulfill Promise. Remember, once the Promise is set, that's it, no changing it again. In fact, Fulfill Promise will error out if called twice on the same promise.
Something else really cool we can do is fulfill a promise with another promise. This may seem pedantic at first but it can help keep your code cohesive by passing the responsibility of fulfilling a Promise to another process. For example, if you have a message broker that just forwards a message, you can have the message broker fulfill it's promise to the caller with a promise from the callee.
We can also reject a promise with an error message that will be returned by any Wait on Promise that tries to read it. Rejecting a promise does fulfill the promise so you still cannot set the value later and you cannot reject a promise again.
Finally, we have Destroy Promise. It does exactly what it says on the tin.
I'd love to hit some more of the design points from https://promisesaplus.com/ (mainly adding Then callbacks) but I figure it's at a pretty good spot to share and get some feedback. I'd also like to try to figure out network communication at some point but that's probably a ways away (without some help anyway Smiley Wink).
I'm hosting the code at https://github.com/kgullion/LabVIEW-Promise if you are interested in checking it out or contributing!
Motivation: in my recent project I have got a request from the end user that it would be nice to store configuration data in the same TDMS file where we store measurement results. Of course, we can create this feature programmatically, like we parse through the typdef cluster, using label names and different data types, we can create a kind of API for a TDMS Cluster read/write. However, it is difficult to make it generic, and this is an extra work anyway.
So it would be nice to save my complex Typdef cluster into TDMS, where I store measurement results in a user readable manner (via the Excel plugin) inside different groups and channels. The stored configuration cluster does NOT need to be user readable!
Since TDMS does not have this feature, as a dirty and simple workaround, I will always produce two files during measurement/data processing sequences: a TDMS, and an INI file (via the OpenG Write INI Cluster), then programmatically ZIP them into a single file for data backup (for future reference, it is safer this way).
Would not be nice if we could just write a Typdef cluster to and read from a TDMS file directly?
Like what we can do with the OpenG Read/Write INI Cluster VIs. I understand there is a strong reason why TDMS files limit the data types we can write to them, and it is not allowed to use undefined data sizes, like Variants, strings. Well, we can write strings to TDMS files, but there are some issues/difficulties with this approach if we want to go through a Typedef Cluster->String->TDMS file storing route. Hoovahh had a post about these challenges 2 years ago, where he mentioned he might make it into an Idea, but I could not find it in this forum board, so I make it an Idea: https://forums.ni.com/t5/LabVIEW/Read-Write-Variant-to-TDMS/m-p/3334203
I imagine, NI could implement such feature into TDMS in a similar way, like there would be an "internal part" of the TDMS file where the Cluster is stored as a Variant in binary format. I do not know how the internal things work in a TDMS file, but I imagine such new feature implemented as an extra data type for the TDMS Set Properties would not hurt the speed performance of the Group/Channel level things...?
Idea is quite simple - add to instrument drivers project wizard template for switch/MUX/matrix devices.
Custom switching boards are commonly used, b/c for some simple purposes it is cheaper to make custom design with simple functionality (some micro processor which controls relays), and which could communicate by serial line. Then instrument driver - is ideal solution to create simple API in LabVIEW for its control; but unfortunately, there is no template for such types of devices in New Instrument Driver project wizard.
If you are using TCP to communicate to a different code environment, you may want to set some of the socket options. For example, for responsive control, you will want to disable Nagle's algorithm. There is currently no obvious or easy way to do this. TCP Get Raw Net Object.vi in <vi.lib>\utility\tcp.llb will provide the raw socket ID, but you then need to call setsockopt() on your particular platform using the call library node. You can do this with the code provide here. A much better way would be adding a property node to the TCP reference that allowed you to set and query the options directly.
This was issue number 7737579.
I wanted to be able to export and fill in the fields of a PDF Form.
There is already the ability to work with Word, Excel, and various other data bases, but a PDF Form is not supported.
I know there are other ways to skin this cat, but in my case, we have many PDF Forms already made that are test reports.
To have Labview run the test and insert values into the named fields of an existing PDF Form seemed like a no-brainer to me.
Anyway, that is my suggestion for you guys to chew on.
Thank you,
Michael
I just had a call with a customer that have a problem:
we cannot install multiple version of drivers to develop applications with different driver versions.
This problem happens to our partners.
Example:
I have a customer that want to uses LabVIEW 2014 and another one that uses LabVIEW 2017. So I would like to make a project with 2014's dependencies and another project with 2017's dependencies.
So the idea is to manage the dependencies in the project itself.
Antoine
The operating system takes a long time to open an application when you need to open many file, if we group files in larger files, the times are reduced. With LabVIEW we can create libraries ".llb" is a really funky zipfile, but it is a file that was introduced to provide functionality in the past.
Like Java uses the ".jar" to create packages and distribute the code more easily. They are built on the ZIP format and typically have a ".jar" file extension; LabVIEW uses the ".vip" to create packages with VIPM. VI Packages are similar to zip files in that they contain all the VIs and resources for a specific LabVIEW add-on. But ".vip", are not recognized by LabVIEW in the project tree, instead ".llb" files, we can access its contents from the project tree of LabVIEW.
From a labview project, we can build a ".zip" file. (Build Specifications>New>Zip File). But if we enclose the project in the .zip file, it does not show us the content tree.
My proposal is that LabVIEW can recognize the contents of the ".zip" files, as well as the ".vip", to be able to access its contents and be able to use the lvlib, lvlibp, class, vi ... that are contained. In this way, we can use ".vip" files in <vilib> \ *, <urllib> \ * ... and be able to use its contents without needing to unzip it.
From LabVIEW Project, we can access the last modified files, from the menu File>Recent Files.
When we work with a large amount of files, it is very useful, so as not to have to navigate the whole tree, to find the last modifies files.
But not always we will want to access the recently modifies files, so I propose to create a quick access category in the project tree.
When we work on a project with a large number of library, class, vi,... it can be difficult to find the files that need to be modified, so it can be very useful to have quick access to those files that the developer considers.
This is in addition to New LabVIEW Installation Retains Options
During LabVIEW installation if it detects a previous version of LabVIEW has been installed it should present the user with the option (or have a flag when running the installation to allow this to be done silently) to import all VIs which are not installed by default that are present in the following folders:
  • vi.lib (VI Package Manager installs packages to this location by default)
  • instr.lib
  • user.lib
Upon importing the VIs to the new LabVIEW installation it should also mass compile them to the new LabVIEW version so the user is not faced with having to save loads of VI dependencies each time the user opens a VI which uses them.
This would make the getting started with the new version of LabVIEW a lot more seamless when just upgrading from a previous version.
I have several LabVIEW applications that I work on, and each of them has a Perforce workspace associated. Every time I switch to a project that is in a new workspace, I have to dig through the SCC configuration menu to switch workspaces, which takes a while.
It would be really sweet if LabVIEW recognized that a project file was in source control, and associated the workspace with the project file. (Especially because I could have two application projects open, each in its own workspace.)
NI LabVIEW allows VIs with invalid characters such as "?" in the filename inside an LLB file as shown below:
However when it comes to building a Source Distribution / TestStand Deployment that uses this file it returns an error as shown below:
This inconsistency within LabVIEW is quite frustrating where one part allows invalid characters in the filename and another part will return an error. Since the invalid characters are allowed in VI filenames within LLB files I would suggest that the LabVIEW build tools also handle them graciously.
During the build process it could quite easily rename the file "pi40iv Can Connect Channel?.vi" to "pi40iv Can Connect Channel_.vi"  and link the VIs that use it to the newly renamed file. The build tools already contain the ability to rename files by adding prefixes so something like this would not be that difficult.
While people may argue to just rename the filename within the LLB and be done with it, the fact that the LLB is a perfectly valid file in the Development Environment but causes problems when trying to do a build is a problem that should be rectified.
The LLB in question is one that is not developed by us but is part of a Pickering Driver Installation obtained from the following location:
http://downloads.pickeringtest.info/downloads/drivers/IVI/
Therefore every time we install a new version of the driver we would need to rename the VI filename within the LLB file.
Having a continuous integration system is an essential component of software development:
Continuous Integration ProcessContinuous Integration Process
This system requires automating the building process.
The LabVIEW development environment unfortunately does not have built-in tools to achieve this easily.
But the community has supplied a few sollutions to achieve this: CLI Tool
On of the biggest hurdles that yet remain, is the fact that the application builder is inherently tied to the development environment.
This requires a valid license for the environment and all toolkits / technologies used in the source code of the product you intend to build.
My proposal would be to have a special "CI" license in which all required modules and toolkits are activated, and that would allow the development environment to launch in some sort of protected mode that prevents users from actively developping code (while still allowing scripting functions), for the sole purpose of building applications.
The LabVIEW Task Manager is an outstanding tool for debugging LabVIEW Applications. It should be included in LabVIEW in my opinion.
Hello Guys,
as we are transforming our Testing Application deployed as Executables to something more "state-of-the-art", I found the Remote Panels solution could suite our needs.
Remote Panels are a nice solution, but they rely on LabView RTE and Browser Plugin on the Client Machine. I don't think this is state-of-the-art, since the Web Technologies Wars have are over and Plugins lost the Fight.
I found some similar ideas in the Idea exchange, but none of them hit the point directly. So heres my Proposal:
Replace the reliance on LabView RTE and Browser Plugin with a HTML 5,JavaScript and Websockets solution, that runs on any modern Webbrowser!
This would bring the following Advantages:
- support for any client operating system (even IOS, Android, etc. possible)
- seamless support for Remote Panels in modern browsers (neither Chrome, Firefox, IE will support NPAPI in the future)
- take advantage of all the PROS of modern web technology (e.g. responsive UI to support Touch UI targets)
- since no Plugin is needed, Clients will have no Security concerns (remember Adobe Flash concerns at Apple)
- no need for any NI customer to build an own HTML5 remote panel solution to bridge this obvious gap of Labview Functionality.
I know there are solutions for Windows Remote Control like VNC, but this does not offer a target UI adjustment for the application. So for example a Ipad Target will not change its UI to be Touch-friendly for the User.
I hope you support the Idea! Best regards and thanks for the Attention, Philipp
The above mentioned toolkit provides great support for S3 and SQS.  For DynamoDb, however, one has to buy a 3rd party driver (ie. Cdata) to provide labview access to DynamoDb.  It would be great to include this support in the toolkit
To generate a VI or set of VIs with a general driver to get low-end FPGA boards to work with LabView FPGA. Parameters will only come from the users to make this dynamic, this would be the total count of I/Os FPGA type, location of I/O items (eg. buttons) in the FPGA board, etc. It would be a bit of work, but also would pay off at the end. Doing such is no more than an extension of LabView if done well, let's say written in an xml file plus it would be a very powerful tool for researchers, and would generate more sales to use LabView FPGA for more researchers, university students, and engineers who want to test a few things without full initial commitment to NI tools.
Incorporate NI Batch Installer Builder into the general application builder suite.
This tool has a lot of potential for end-user use if it is incorporated into the app builder API and suite.  Batch installers can be used for much more than just installing selected sets of NI software (Which this tool is obviously designed specifically to do).  It could be used for creating installers of multiple, cross-project user installers comprising a complete system.  To do this though, the current batch installer builder needs to be made more generic to be of use.
Specifically:
  • Add configuration options to control or disable license dialogs when non-NI provided installers are added
  • Add configuration options to control or disable the user/company license dialogs when non-NI provided installers are added
  • Add configuration options to control or disable the check for NI updates dialogs when non-NI provided installers are added
  • Add batch installer version properties to allow end users to create system versions
  • Add support for 3rd party installer inclusion (Dup from another idea, but I had to repeat it here)
Including this in the app builder would be even better since that should allow project based configuration and control of the batch configurations and potentially even programmatic control.
It would be nice to improve documentation created by Tools->Import->Web Service... wizard.
Especially, I suggest to automatically create Description in created .lvlib Documentation so that it would be immediately clear which WSDL URL is handled by that library. Currently, WSDL URL is only placed as a String constant in Open Web Service.vi which is not really convenient.
Thanks for understanding and support.
