Community Browser
Top Authors
Post an idea
It would be nice if there was a IMAQLinearSums to compliment IMAQ LinearAverages.  Here the sums across rows and/or columns would be calculated.
In audio industry I always use logorathmic frequency (X) axis and often also logarithmic Y-axis. Like from 20 to 20kHz but not linear as in Labview but logarithmic as in Bode-diagram.
Today, labview doesn't understand these. They can show them if you select that your graph-window to have logarithmic axis. But the waveform-type itself doesn't. In the waveform type you have f0, df and Y. But df is not a constant if you have log axis.
Also, the limit-testing methods doesn't understand logarithmic axis either.
I would appreciate it if in a future version of Labview it will allow the use of logarithmic axis.
I made an improved version of String Subset:
If offset is non-negative, the returned string will start at the offset# position in string, counting from zero.
If offset is negative, the returned string will start at the offset# character from the end of string.
If length is given and is positive, the string returned will contain at most length characters beginning from start (depending on the length of string).
If length is given and is negative, then that many characters will be omitted from the end of string (after the start position has been calculated when an offset is negative).
It would be nice if it could work like this by default (no additional inputs needed)
I need a Gantt chart to show the order of a number of events from a log file. The X-axis was to be time, and a number of categories were listed along the Y-axis, similar to digital plot.
I wanted to represent each operation by a horizontal bar starting at the start time and ending at an end time. Multiple events could happen for each category over time. Ideally when hovering over an event, details should become visible. The end result would look similar to what you may know from MS-project, but is not quite the same.
Eventually I ended up drawing the whole thing in the picture control. While passable, it's not as clean as I want it to be and it's a work around. It is not easy to incorporate zoom, highlight elements etc.
Later on, I was completely blown away by an implementation of a similar Gantt chart in JFreeChart. It was zoomable and customizable every which way. If you don't know JFreeChart - check it on the web. It offers a highly customable graph api to the Java community for free (some 40,000 developers are incorporating it in their Java programs). The problem is... it's in Java and Labview can't touch it.
So what I would want is either a Gantt chart in Labview, or (maybe better), a Java container with the whole support of references, methods and properties (if possible), just like active-X and .net support.
The example graph is a very simple one. Now imagine 100 line items, each with hundreds or more occurrences, zoomable, expandable, color coded, labeled, etc.
My idea is about the representation of arrays in the "Probe Watch Window". At the moment you only can scroll through the values of a array/multidimensional array if you have a Probe on a array wire. If I want to know the dimension of the array I have to scroll through the whole array until a value is grayed. Because of that it's easier to build in a "Array Size.vi" to find out if my arrays have the right dimensions but it would be more comfortable if I could see it already in the Probe Watch Window at the Probe Display
In summary it would be very helpful if I could see the dimensions of a array at once in the Probe Watch Window.
It would be nice to have the AI assistant feed back a mathematical equation based on the vi. If I use an equation to build a vi, the AI should be able to feed that back to me.
Being able to initialize arrays as empty sets would be handy - not just as 0 or NaN.
A Diagram Disable structure lets all the code that isn't inside of it execute but not what is inside of it. I think it would be helpful to put a structure around a snippet of code and execute only what is inside the structure. I usually copy and paste it into a new vi but it would be helpful to have that functionality within the vi i'm working on.
I know this idea has been coined already in A new head-controlled while loop, though it was closed becasue it didn't receive more then 4 kudos. That was 3 years ago and I didn't get any vote because I wasn't aware this post was out there. I'd like to re-open the discussion. Or for how long do we close suggested topics because at the time, there was not enough interest? It is not al that difficult and yet we are 2019 and NI still didn't solve this (as well as taking the square of a united input doesn't square the unit).
I have been programming a lot in LabVIEW and generally love it, but I also find it quite frustrating that you can not do the classic "check condition first, then run". I alos find the classic arguments not valid.
Some argue that it is easily solved using a case structure and while loop, which is not equivalent. One solution is to put the while loop inside the conditional loop, which forces you duplicate the conditional code and good programmers don't like duplicate code. (You could create subVI though, but that is also creating a lot of overhead for both the programmer as the program at run-time). Another solution, as some suggested here, is to put the case structure in the while loop, but then if you are indexing the output, you output a array with one element, whereas you probably wanted to output an empty array. In this case you can work with conditional terminals but that is also a lot of overhead and there is even a bug in LabVIEW when you output multidimensional arrays in this way that are empty and later on try to iterate over it, a for loop will execute the inside of the for loop, although the array is "empty".
I also find the argument that it is a rare case not compelling, I myself experienced this often while programming and the whole sense of a while (or conditional for) loop is that you don't know beforehand how many times you will have to iterate it. So it might be as well that you don't even have to iterate it a single time. That sounds reasonable, no? Otherwise you would use for loop. It is actually the other way round: the classic "do while" is a rare case (that's why textbooks first learn the while loop).
I also don't agree with the fact that the way LabVIEW works, it is not possible. I understand that you need a value for non-indexing terminals, but that would simply be not supported in this type of loop. A "check first then run" kind of loop would only work with iterating terminals (which can be empty) and shift registers (which can take up the value it was initialized to).
A seperate part of the loop's body must be reserved for the conditional code (for instance a rectangle that is fixed at the left underside of the while loop rectangle), just like in most languages where you have to write your conditional statement in brackets as part of the loop statement...
This type of loop would also solve the problem that you often have to delete the last element of your indexed array because the condition for which you probably wanted it, was no longer true (but the loop has excuted first after deciding that).
Lastly, it would give new LabVIEW programmers that come from any other language more familiarity with what they know. As this is reasonably a rather big flaw in LabVIEW (see argumentation above) that is some common and basic in other languages and you are likely to stumble on quite soon when you start experimenting in LabVIEW, it might just make you turn around right away, as it was almost the case when I first started programming in LabVIEW and didn't know how the rest of the language and environment is very beautifull and well designed.
Wiring complex time waveform or complex wdt plots only the "I" or real portion of the complex signal. It should plot the Real and Imaginary as two plots overlayed. Always have to do that when plotting complex data and wastes time and clutters the diagram as well.
The data reduction algorithm used by Citadel for logging values inherently assumes that only the absolute magnitude of the change is relevant; that means that a single value for the resolution and the deadband is sufficient for the whole value range to be monitored.
There are situations, though, where the underlying value could span several orders of magnitude. In such cases, it would be useful to set deadbands on the minimal relative change, instead.
The current workarounds are either to reduce the deadband to a tiny value (thus logging much more large data than needed) or to log the logarithm of the value, but that involves an additional step in writing to the SV/reading histories. It would be nice to have a built in option for that.
One of the more important and useful functions, especially for exploratory data analysis in R, is the ability to take N samples from an input provided set with or without replacement.
LabVIEW should have that.  It would be relatively straightforward, and would start moving G toward having more shared Venn-diagram with R.
https://www.rdocumentation.org/packages/base/versions/3.5.1/topics/sample
Personally, I think you should look at the NIST EDA techniques library, and built a toolset off of it. https://www.itl.nist.gov/div898/handbook/eda/section3/eda3.htm
It is tax-funded source code, so it is something you should be able to access and integrate without too much work.
https://www.itl.nist.gov/div898/handbook/dataplot.htm
We can get the top level VI using property nodes / call chain, and we can also determine the running state of any specific VI (given a path).
It would be really useful to know which VI was running as any point in time (without resorting to execution highlighting) - not really applicable to time critical applications of course.
Uses for this include:
1) the abilty to change a VI execution state from Modal to normal with custom created dropins - if required.
2) Automation - it would be really useful to retrofit projects with a tool/dropin for soak testing / debug which detected certain windows - normally these would be modal dialogs and entered data in them to allow the program to continue (I know these features can be built in at the start of a project, but dropping in later would be very powerful for pre-existing ones and allow the use of the NI dialogs.
3) simple debug - code is stuck, exection highlighting is not showing where. This would give the answer.
James
When FFT data is shown the most interesting data occurs as vertical lines or peaks.  When interrogating the data with plot cursor there is not a cursor type that will show the data underneath the cursor. See the plots belowDisplaying image.png
The line style of the cursor can be changed to some type of "dashed" to show some of the data, however there is not a current style of cursor that has the benefit of showing a line that is drag-able without covering the data.
One possible solution is add a select-able cursor type that will show the line above the Y value but not below. So when the cursor is moved to a peak the Y value of the cursor is at the peak, there is a small circle or box and a line from the Y value going positive but no line below the Y value going negative. Current cursor style.PNG
It'd be nice to have a compound arithmetic function of "Greatest" and "Least" which will output the largest or smallest of the input values. It could look like this but with re-sizable input nodes.
Also, I think the top way is the best way to find the greatest in a set, but let me know if there is a better way.
Two recommendations:
1) Add an OSI Read VI for N wavelength spectra that returns each wavelength spectrum as a waveform (i.e. an N x number of channels array of waveforms). This will provide the time stamp of each wavelength spectrum, and will also be more efficient that reading one set of channel wavelength spectra at a time.
2) Add a VI that applies the wavelength scaling to wavelengths.  This will allow the user to apply their own power spectrum peak search algorithm to wavelength spectra, whilst still applying the current wavelength scaling algorithm. This will free the user from having to use the OSI peak search algorithm.
We have found that the peak search algorithm utilised by NI-OSI performs poorly when the peaks in the power spectrum are poor quality, and that a much simpler algorithm yielded far better performance. Our algorithm was to simply report the maximum power wavelength in the sensor wavelength range if it was above a minimum threshold. This is in significant contrast to the NI-OSI algorithm that searches for peaks across the entire power spectrum using four algorithm tuning parameters, identifying all of the detected peaks that fall within the sensor wavelength range, and then reporting the one with maximum wavelength.
For reference, we have a PXIe-4844, and are using NI-OSI 16.0.
Definition of the problem:
To find the scope of an method in code quickly there are two options:
  1. Either place it in another VI or in a child class method, if it breaks you know the scope.
  2. Look into the project explorer and find it there.
It would be nice if we could avoid the above two methods of finding out the scope.
Current solutions:
Of course we can add text in the icon (limited space) or rename the method so it has the private/public/community name in the method (long file names and a loth of work when changing the access scope) and even add descriptions for the scope which requires the context help window to be open.
But there is a more elegant solution: In the project explorer there is an way to find out the scope of the Methods in a single glance by the glyphs used on the icons.
So incorporating this in the Icons of the methods makes sense. Even better there are already a glyphs of the protected and private methods.
Proposed Idea:
Changing the access scope into private/protected/public or community automatically add an layer with the corresponding glyph of the access scope. This makes it clear what the scope of the methods are and thus avoiding breaking the code/using long names/writing it in the icon or place it in the description. Automating this also removes a loth of extra clicks to get the same result.
This NIST site defines a non-integer factorial:
http://www.itl.nist.gov/div898/handbook/pmc/section3/pmc32.htm
The result of the computation is used in statistical process control.
I think that LabVIEW should have its VI's compatible with NIST, and "engineered for process control", seeing how they control processes.  The control shouldn't exclusively about operation, but should also have bounds, and quick/effective alerting for out-of-control condition.  (OOC).
The signal processing VIs only tend to support DBL waveforms and waveform arrays.  Since waveforms can themselves support many data types, the signal processing VIs should also be able to adapt to non DBL based waveform data.  EXT at the very least.
Excel has been around forever, and that means it is optimized for a mix of demographics.  Something qualitatively similar can be said for most tools that have been around for a while, but what differentiates end user group includes the "canonical use case for the feature", and market/economics.  (I am convinced that if NI could make a sustainable/defensible few billion per year with a spreadsheet, then it would make a spreadsheet product.  It is business 101.)
One of the tools that Excel, Open/Libre office, MatLab, R, and Python have that LabVIEW doesn't really have (MathScript has it, but not integrated) is a variation on "Goal Seek" [1, 2, 3a/3b, 4, 5 ].  It is trivially easy to say "make the output of my function this, by changing this input" in all of those.  It can be done in LabVIEW, but it is not a "one-liner", and that comes from the UI being engineered around software creation, but not around data exploration.
I recommend a tool that can work on the front panel of a VI that allows me to attempt to set an output to a particular value by varying an input.  It can work with fzero, fsolve, or any number of optimization.
The demographic here is different than the conventional LabVIEW market in that it is the data-explorer.  This is for folks who want to understand something new, not seek to wrap an understanding they already have into a package.  Instead of capturing data in LabVIEW and processing it in another tool, why not start moving the line so more is done in LabVIEW?  The greater return of value for the same price means continuous growth of market share.  That isn't a bad thing.
