Community Browser
Top Authors
Post an idea
LabVIEW  has a somewhat hidden feature built into the variant attributes functionality that easily allows the implementation of high performance associative arrays. As discussed elsewhere, it is implemented as a red-black tree.
I wonder if this functionality could be exposed with a more intuitive set of tools that does not require dummy variants and somewhat obscure VIs hidden deeply in the variant palette (who would ever look there!).
Also, the key is currently restricted to strings (Of course we can flatten anything to strings to make a "name" for a more generalized use of all this).
I imagine a set of associative array tools:
  • Create associative array (key datatype, element datatype)
  • insert key/element pair (replace if key exists)
  • lookup key (index key) to get element
  • read all keys
  • delete key/element
  • delete all keys/elements
  • dump associative array to disk
  • restore associative array from disk
  • destroy associative array
  • ... (I probably forgot a few more)
I am currently writing such a tool set as a high performance cache to avoid duplicate expensive calculations during fitting (Key: flattened input parameters, element: calculated array).
However, I cannot easily write it in a truly generalized way, just as a version targeted for my specific datatype. I've done some casual testing and the variant attribute implementation is crazy fast for lookup and insertion. Somebody at NI really did a fantastic job and it would be great to get more exposure for it.
Example performance: (Key size: 1200bytes, element size 4096: bytes, 10000 elements)
insert: ~60 microseconds
random lookup: ~12 microseconds
(compare with a random lookup using linear search (search array): 10ms average. 1000x slower!)
Thanks!
When programming with large applications, often times you'll have clusters carrying a lot of information.  If you hover over the cluster wire and observe Context Help, you might see something like this:
This Context Help window above is rather large and doesn't necessarily make it any easier to see the structure or contents of the cluster. My proposed idea calls for the ability to expand or collapse the cluster contents within the Context Help window, such as this:
What do you think?
This is written as both an Idea and as a Community Nugget.
Did you know there exists a function that decreases code fragility when it comes to typecasting and type converting datatypes? It's called 'Coerce to Type', and I bet you've never heard of this function unless you have kept up with this conversation. Thanks to RandyP for creating that Idea which culminated in a 'public' release of the Coerce to Type function.
21195iD087EF25489F6CED
Since that post, I have become aware of potential risks/bugs I had been proliferating in my coding style. First, I will briefly describe my understanding of the difference between typecasting and typeconverting in the context of LabVIEW. Next, I'll show a few use cases where this node increases code robustness. Finally, it's up to you to Kudos this Idea so we get Coerce to Type officially supported and in the palette!
Simply, "type converting" preserves the value of a wire, and "typecasting" preserves the raw bits that express that value on a wire. These two concepts are not interchangeable - they perform distinctly different data transfer functions (which is why they show up on two separate subpalettes: "Numeric>>Conversion" and "Numeric>>Data Manipulation"). Then there's this new function: Coerce to Type. I think of it as a Coerce-Cast combo. The data input is first Coerced to the datatype harvested from the top input, and then it is typecasted to that type.
Dynamic event registration is sensitive to the name on the wire, and for documentation's sake it has historically been important to typecast the event source ref to achieve a good name. Well, typecasting refs can get you into trouble (ask Ben), especially if you change the source control type while forgetting to update your "pretty name" ref constant.
21187iA83D4F02211D2DCB
My next favorite example is when you need to coerce a numeric datatype into an enum. Sometimes it's impossible to control the source datatype of an integer, while it's desirable to typecast the value into an enum for self-documented syntax inside your app.
For instance, take the "standard" integer datatype in LabVIEW - I32 - and cast it to an enum. You're going to get some unexpected results (assuming, you expected the *value* to be preserved). Consider the following scenario:
  1. You desire to typecast a plain integer '2' into an enum {Zero, One, Two, Three}, and after 45 minutes of debugging, realize "Typecasting" has hacked off 75% of the bits and clobbered the value. Drats!
  2. The enterprising engineer you are, you determine how to fix the problem with a deftly-placed "Coerce to U8". (This is one of the fragile errors I proliferated prior to learning about this node)
  3. Maniacal manager/customer comes along and says "I want that enum to count to 10k". Drats again. A datatype change from U8 to U16 for the typedef'd enum, and a lot of typing with the wretched enum editor. Finally, two hours into testing and wondering why the program doesn't work, you realize you also forgot to replace all of the Type Converts to U16 (this is the definition of fragile code: you change one thing, and another thing(s) breaks).
  4. Rockstar Programmer Epiphany: use Coerce to Type, bask in your robust code. You even enjoy data value preservation from floating point numbers.
21191iD3339D40A531F181
Finally, typecasting can generate mysterious failure modes at Run-Time, but Coerce to Type can catch errors at Design Time. This is especially helpful for references (see above), but can also prevent some boneheaded data gymnastics (see below). Whew! Saved by compiler type resolution mismatch!
21193iC698E122C5BE16AC
In short, now that you realize you need this function, I hope you will want to see it added to the Data Manip palette.
Penultimate note: Coerce to Type is neither a replacement for typecast nor any of the type converts!!! There are distinct scenarios appropriate for each of the three concepts.
Ultimate note: please check the comments section, because I expect you'll find corrections to my terminology/concepts from GregR, et al.
It would help a lot if we have an option called pause on first Error. So that the VI at the node/primitive that generates the error and highlights that node so that user decides to continue or abort.
Data Type Representation Pallette
Can the the options on the data type Representation pallette be changed from grey to match the color of the numerical icons and terminals?
Thank You!
Melissa McQueen
For distribution, only package necessary libraries in installer packages built with the project. A lightweight UI, server, or client does not need a full 70MB+ installer that bloats out to a few hundred MB's once installed! A colleague has remarked that the total size of our LabVIEW application+RTE EXCEEDS the entire size of the XPe image running on the embedded computer! This becomes an issue when distributing software upgrades to places in the world without high-speed internet connectivity.
It would be helpful to have an array control property that fixed the number of elements in the array control to the specified size.  This would allow the developer to programmatically set the array control dimensions such that the user is unable to add new elements to the array.  This is specifically necessary when the number of elements in the array control may vary and may also be too large to display all of the elements.  If the scrollbar(s) are visible, then the user will always be able to add a new element add the bottom by editing the available empty element value.  This is undesireable if the developer wants to prevent the addition of new elements by the user.
Please see the discussion forum post below for the details of the issue and current workaround.
http://forums.ni.com/t5/LabVIEW/initialize-array-control-dimension/m-p/1221930#M520867
Dan
The Arduino Due is a 32 bit ARM based microcontroller board that is destined to be very popular. It would be great if we could programme it in LabVIEW. This product could leverage off the already available LabVIEW Embedded for ARM and the LabVIEW Microcontroller SDK.
The Arduino Due is currently in developer trials and is due out later this year. It is expected to be about $50 and is open hardware. The ARM chip is an Atmel SAM3X8E ARM Cortex M3 running at 84 MHz resulting in 100 MIPS of performance. By way of comparison, the current LabVIEW Embedded for ARM Tier 1 (out-of-the-box experience) boards have only 60 MIPS of processing power.
The Arduino brand has an enormous following and Google has selected the Arduino Due for their recently introduced (28 June 2012) Accessory Development Kit for Android mobile phones and tablets (the ADK2012).
(By the way, the currently-available LabVIEW Arduino toolkit does not target the Arduino (and couldn’t since the Arduino Uno uses only an 8 bit microcontroller). Instead there is fixed C code running on the Arduino to transfer peripheral information to the serial port and back. That is, none of the LabVIEW target code executes on the Arduino. This idea is for LabVIEW code developed on a desktop to be transferred and execute on the target Arduino Due.)
Wouldn’t it be great to programme the Arduino Due in LabVIEW?
when I have to rework a vi, i usually start by putting the existing code in a disable structure
and then start working in the disabled 'case'.
Quite often I end up trying to replace the disable structure with a case structure to test the new or reworked vi.
Now I have to copy everyting into a temporary vi, remove the disable structure, put a case structure in place, paste again and rewire iputs and outputs.
Please add the ability to replace the disable structure with a case structure.
The current behavior of LabVIEW is as such:
The pick list of event data strips the cluster, only allowing access to the elements inside the cluster. In order to manipulate the native datatype, you must reconstitute the cluster inside the event structure, a performance hit on large data structures firing at quick event rates. This is not to mention a messy FP.
I suggest that User Events preserve the clustered event datatype, allowing the programmer to access to the native datatype on the consumer end. The option to select only the element "Clustered Typedef.Array of I32s" of course still remains, but is not forced upon you. (Note that the below block diagram is NOT a direct LabVIEW screenshot... brought to you by trickery and a paint program. I clustered the cluster on event datatype [not shown] so that the event structure could eat the outer layer)
My motivation with this suggestion is directly linked with my other post on the Big Typedef Issue.
LabVIEW loops are quite flexible and allow me to do just about anything I want, but I often find myself writing the same code over and over again trying to iterate across different data types and data structures. There are several situations where smarter looping constructs could greatly simplify my code. One simple example is stepping by a delta between a minimum and maximum value. Currently, I have to calculate the number of iterations required ahead of time (for a for loop) or do a comparison with the maximum (with a while loop) and use shift registers to maintain the intermediate value. I'd like to be able to wire the max, min, and delta to my loop and have LabVIEW do the required calculations for me. The iteration terminal could also adapt to the proper data type given the input parameters. Perhaps the iteration terminal would have two outputs, one with the current iteration count and the other with the proper iteration value.
Another useful feature would be allowing me to wire a queue reference to the loop count terminal of the for loop and having it automatically pop each value from the queue and feed it to me through the iteration terminal. It would do this until there are no values left in the queue or until the code stops the loop. One could write an algorithm that pushes new points into the queue from within the loop or push the current value back onto the queue for later processing.
I'm sure there are other useful iteration strategies that are fairly common, please share them with the community
We currently have an option to "Run executable at the end of installation".  This is useful for installing other stuff required by your application.  However, we also need the ability to clean up these things during the uninstall process.  So, I'd like an option to "Run executable at the beginning of uninstallation".
I liked the new DBL on the palette that we got last year or so - saves a step. But, it should NOT adapt to entered data by default! Why would I specifically place a DBL only to have it change?
If unwired it would default to 0, and at least let thread switching occur.  You could maybe right click on the loop and remove the wait node to make it run as fast as possible (like it is now), but it should be there by default...  Maybe also right-click on it and get to choose between "Wait (ms)" and "Wait until Next ma Multiple"?
(PS: I know that you can do this using timed loops, but I'd like to see it in all of them - I've seen too many "programmers" complain that their CPU is at 100% because their loops are going nuts).
I have pondered this and not sure it is possible but it would be nice to allow using case structures to work with vi server references.  It is very tedious to test each type with a cast to more specific and the for each type and check for error (current method or itterating through the class hierarchy).
I know that subclasses pose an issue, I would like to see for the case structure to limit each case to select the highest level (ie g object) and the distince cases are error or any direct class child of the specified parent type class.
The Use case I see is for handling itterating through controls from an array of controls (if the control is a boolean do something different than if the reference is to a string control).
Could be very nice for scripting.
Hello everybody,
(as suggested I will separate my idea Expand the functionality of Event structures into four seperate ideas to allow giving kudos separately.)
Make it possibly to dynamically register references like tcp/ip, visa, queues, etc. for Event structures. Possible events are "new bytes at tcp/ip", "new bytes at seriel port", or "connection closed". In the case of queues it could be the same function as "Dequeue Element" or "Queue referenced closed". There are certainly a lot more of similar references, which could be registered for catching events, which up to now we have to poll regularly or use other event functions (as in the case of visa -> new bytes at seriel port). Benefits are: no more regular polling of changes, better integration of several functions (like using queues to communicate with GUIs instead of dynamic user events), and in my opinion just better code.
Regards
Marc
As much as I love Quick Drop, I don't love this:
This delay occurs because we have to load all the palette information in the background to be able to drop objects by name.  You can choose Tools > Options > Controls/Functions Palettes > Load palettes during launch to front-load this delay during LabVIEW launch, but (1) a lot of you don't really like the longer launch time much better and (2) a lot of users still don't know about this setting.
I'm sure there's a way to solve this problem and make Quick Drop instantly usable, but I don't know enough about the underlying palette code to get it done.  Solving this problem, by the way, could have positive side effects on LabVIEW launch time, palette search performance, and maybe some other areas as well.
Please implicitly consider array index during index / replace elements in In Place Elements Structure if I am starting from Index 0
Present method:
Expected method:
[admin edit 2021-02-24]: placed images in-line with text and removed them as attachments
(Similar title here.  Different concept.)
Many OO languages provide an Interface construct that allows objects in unrelated class hierarchies to expose similar functionality that can be called via common methods.  For example, a Car class and a Race class might both implement a Start method.  Unless their common ancestor has a Start method (which may not be practical) there's no way for me to take advantage of dynamic dispatching.  Interfaces allow an object to temporarily disguise itself as a different object so I can use a single vi on multiple objects.
Using the Car/Race example, I would like to be able to create an IStartable interface construct that defines a Start method.  Car and Race, in implementing IStartable, create their own Start methods that will override IStartable.Start.  I could then transform the Car and Race objects into an IStartable type and wire that into IStartable.Start.  IStartable.Start would then automatically transform each object back into its original type and call its member Start vi.
A couple points:
  • Classes need to be able to implement multiple interfaces.
  • There needs to be a way for class designers to indicate which interfaces it implements.  Setting that up in the class property dialog box seems like the best solution.
  • There also needs to be a way for class designers to designate which member vis to use when overriding an Interface method.  I can't think of a good way to do this in the vi itself, so I'd also manage these settings in the class properties dialog.
  • The illustration uses a Type Cast prim even though the actual type is not being changed.  It would need a new prim.
  • I've toyed with the idea of hiding interfaces on the bd by having an 'Invoke Interface Method' node that would automatically do the transformation and call back into the class' overriding method, but I think that restricts developers too much.
                     this time, I hope this idea was not already proposed! Smiley Frustrated
