Community Browser
Top Authors
Post an idea
Editing the Font Styles and Size of a text, can't it be Simpler? rather than a lot of mouse clicks each time??
Many had suggested the use of Key board shortcuts, but it may be used for some other things. But Why shouldnt we use a dialogue box instead?
The problem is lot of mouse clicks to go to Dialogue font, Styles/size and then to the respective selection like,
The Key board shortcuts are being used for other functions., But Why shouldnt we have solution like this??
I am not sure whether it can be done or someone already suggested., but i didnt come accross anything like this when i searched for.
Thank You..
Sometimes we have a need to do some mild synchronization between otherwise parallel tasks. Typically we would use a flat sequence (but there are also exceedingly fancy tools such as "Rendezvous"). Even a flat sequence is often overkill for the given situation: It is a 2D object with it's own diagram and input and output tunnels. We need to decide what should be inside and what should be outside.
I suggest to extend the idea to a 1D object: The "Synchronizer Bar". It is basically a flat sequence with zero frames, condensed to a single vertical line (Maybe we could even allow kinks in it???).
The function is very simple and immediately intuitive (as anything in LabVIEW should be!!) and can be described in a single sentence:
"No data can leave any of the tunnels until all tunnels in the structure have received data."
Ideally, we should be able to "free-hand draw" this structure interactively with the mouse and a tunnel will be automatically generated for each wire we cross.
Here is a dumb (but illustrative) example (ignore the code itself). That's how it could look like.
(At the moment I simply merged the edges of a flat sequence, but I am open for prettier suggestions ;))
Overall, it should be closely related to the flat sequence and include certain right-click actions (e.g. Add frame before/after, which would expand it into a flat sequence).
There should be an easy way to replace a control/indicator/constants of a certain type to an array of that same type, and vice-versa.
Message Edited by David_L on 12-04-2009 02:06 PM
Clusters are powerful and necessary, but they can easily clutter up otherwise immaculate code.  Why not have a "View As Icon" option (a la Express VIs) for cluster constants?
Right-click menu change...
There have been similar suggestions, but I think we need a clean, simple solution.
A great time saver would be if we could drag or click to switch connections directly in the connector pane instead of having to disconnect and reconnect controls.
This can be a simple two click process:
If there's already another control\indicator where you click, they get switched.
We have (collectively) complained about coercion dots many times on various LV forums -- they are nearly invisible and there are three different kinds, which require different levels of concern. The problem is that there are very few pixels within a terminal and there's no space for any pattern to differentiate the three kinds of coercion (and changing colors is a problem for reasons discussed here in the Idea Exchange).
Another LV developer had an idea that I liked: add an option to view giant coercion dots. We have avoided this because coercion dots bigger than the terminal would interfere with wiring. However, many developers have a policy of eliminating all coercion dots on their diagrams. For those who have such a policy, they could eliminate the coercion dots as they work, and thus might not see any problem from such large dots. Large dots would solve lots of other usability problems that coercion dots have today.
This option could be something in Tools>>Options, but I'd rather it be something in the View or Edit menus so it can be quickly toggled on or off with a shortcut key.
These graphics are "programmer art" -- I just made the three dots look different. Please sumit alternate images for the three dot types if you have better style suggestions. I did make the three dots differ in both pattern and color so that we avoid problems with colorblindness. The type-only was a solid dot, the widening coercion is a bulls eye, and the narrowing coercion is a single ring. Any redesign should definitely take colorblindess into account.
Whenever we create a constant (or control) on a partially connected function, we get not only the same datatype (good!), but also the same array dimensionality (often not so useful).
In the vast majority, I want do do some uniform operation on the entire array, so a scalar control or diagram constant would be much more desirable. I usually end up creating the array constant, then pulling it out of the container, hook it back up, and delete the container. This guarantees the correct datatype (I32, DBL, CDB, etc).
(It is even more tedious to place a diagram constant from the palette and then remember the datatype and adjust accordingly).
IDEA:
When creating a control or constant, and it would result in an array, I would prefer to also have a scalar option.
This little move illustrates it in the case of creating a diagram constant. It should apply equally to controls.
Message Edited by altenbach on 07-11-2009 09:51 AM
        but ...
                   same problem for all functions from the Exponential Functions Palette
                                        much more clear, readable and explicit
The VI documentation window could use some improvement and several additions could be made to make editing the text a lot easier.
Improving adding control and indicator name.
Typically the text in the documentation window does refer to the control and indicator connected to the connetor pane.
It would be very convenient to have this information already in that window so we don't have look it up when needed. Additionally, the control and indicators are typically bolded in the resulting text using the <b></b> tag. It would be convenient if this would be done automatically for us.
In the propose idea (see image below) the VI icon with the controls and indicators is shown and the controls and indicators when clicked do insert their name into the VI description.
Note: The control name may be made to look like an hyperlink to indicate that there are click able.
For example, in the image below, clicking the "Items to filter" will insert the "<b>Items to filter</b> tagged text in the VI description.
Improve general text editing
While fancy text editing is limited in the VI description, adding a toolbar to improve text formatting would be useful.
I think it would be nice if LabVIEW was smart enough to know that when I drop a For Loop around scalar inputs it doesn't auto-index output tunnels - but rather uses Shift Registers - for matching inputs and outputs.
The common use case for this is with the Error input/output - it annoys me how it becomes an Array output.
As it is already wired, inline and not broken, dropping a For Loop around it should not break my code!
Reference or Class inputs are other use case too - I want to pass the same thing around not create an Array
Shift registers are better than non-auto-indexed tunnels (other option) as they protect the inputs on zero iterations.
21826iFF181EE2E7ECE408
This would remove one step required for most use cases, speeding up my development experience.
Today, the enum data type in LabVIEW only allows having sequential numeric values (0, 1, 2, 3, etc.).
It would be very useful to have sparse enums, meaning enums which can have custom numeric values assigned to their strings, just like you can do today with rings.
If you want an example where this will be useful, think of error codes - this would allow you to use an enum on the diagram to select the error, or in a case structure.
Cluster Size as a Wired Input:
  • Easier to see
  • More implicit
  • Nearly impossible to forget to set it (if it were a required input).
It has come up here in a different discussion, but I think it should be a separate idea, so here it is!
If we disable part of the code using the diagram disable structure, the disabled code gets lighter in color. The new compiler is good at eliminating dead code (i.e. things that don't need to be computed because there is no output), so it could be useful if these code parts are also bleached in a similar way to indicate that fact.
Here's how it could look like.
I would even suggest this to be enabled by default. Of course there also needs to be an option to turn it off....
(I was about to write up this idea, but then, searching for "dead code", I found comment by SynchronizationOverhead. So the original credit goes there, of course ;))
Current it is very hard to reliably manipulate decorations using VI server.
LabVIEW need to be able to create explicit decoration references (like it is possible to do on other objects through right click Create>>Reference).
Note: Thanks to TonP for the idea.
Since most (if not all) controls and indicators can be moved around with "position" property node programatically, the X and Y coordinates on the front panel are useful information to have.
As of right now, users have to adjust the position values by trial and error to know what values suit the UI, or maybe make a program to capture the mouse position programatically.
So I've been getting feedbacks from customer about a function where one can view the coordinates of the mouse all of the time. (meaning no programming is necessary)
I was thinking about two methods (see attached)
1. Show coordinates along with the mouse
2. Show coordinates at the bottom of the pane
Today, if we want a FOR loop with a fixed number of iterations, we need to wire a diagram constant to N. We could probably save a few clicks if we could click on N and type in an integer directly. It would also unclutter the diagram. This should of course only work if N is unwired.
Of course the N-Box would grow to the right to accomodate all digits
To later change the loop back to "normal", we would type N into the box or simply wire something numeric to N from the left.
As an example how it could look like, here's a simple cross product implementation (Yes, I know, LabVIEW already has a cross-product, so this is just to show the idea!)
Top: current implementation
Bottom: Same code after this proposed idea has been implemented
As mentioned at the end of my comment here, editing text is a bit clumsy. There should be a text toobar that is similar to what we can find in any other application.
Maybe it could be dynamic so it only appears when editing text.
Here's the quote from the other thread:
One thing that should be improved is the font pulldown which feels so early 1990's. When working with text, we want a text toolbar like anywhere else, (even in the post editor here in the forum!) with a bold, italic, etc. buttons, font and size rings, etc. You know what I mean!
Same information as the '\' Codes Display but easier to read.
Tools like Word and Notepad++ allow you to view the hidden symbols in a string, it would be great if LabVIEW did as well.
Normal Style
'\' Code Style
Symbol Style
