Community Browser
Top Authors
Post an idea
Why dont wires have an optional label associated with them.  Style guides have use label long wires but wires have to be moved often during development, and the labels are not fixed to the wire.  This should be maintained for us.  Right click on wire and add label, with ability to lock label to wire source, wire midpoint or wire destination.
Message Edited by Support on 06-03-2009 03:26 PM
Hello, this is my first post in this forum and I don't found ideas about this topic. I hope you like it.
Well, time ago I started to work with LabVIEW, It's powerful, but there are some kind of issues that I want to explain here. Now I'm get involved in a big project for a very big aerospace company, and I'm developing a complex application to acquire some data and process it. Well, this software is in development by some people and I have an idea for the work flow.
I explain it with an example:
If we have in every VI a little data base with some notes ordered by type or something we can read the code or we can start to work in a VI faster. Imagine that you have an event structure with several cases, and you put some notes like you can see in the following image:
Now, I'm able to revise quickly the code reading all the notes and start working only in the "TO DO" zone. But let's do a more complex design: Now I open my project explorer, and open the "Note manager" that could be like this.
Here it is the real advantage of this tool: All the design are done and now I want to improve the application. Lets go only to the notes that interest to me: "TO DO" notes. If I double click on an element LabVIEW opens for me the VI centered in the zone that is interesting for me. And some more: I can check the work I've done and I can add new notes only with a click.
The more complex the project is, the more useful is this system. So, what do you think?
In line with giving us a better polymorphic VI editor, doing the same for Enums would be great.  The current implementation is SSSLLLOOOWWW and unwieldy.
Please re-visit this functionality to make our lives easier....  So many people create enums via rings for exactly this reason.  This is just unneccessary.
The function Index & Bundle Cluster Array can be quite useful and mimics a bundle in a for loop.
The reverse operation (= unbundle in a for loop!) would be equally useful.
 I wonder why it is not part of LabVIEW. Seems like an omission. 😉
I suggest to add it with the same icon graphics, but with left and right halves swapped.
(See also this example)
Message Edited by altenbach on 06-17-2009 01:21 PM
Simply put, you should be able to put a URL hyperlink in a floating comment to link out to some site.
Imagine being able to add a hyperlink to the mathematical description of a VI that you used. Perhaps you have an internal server of IP Documentation. You could add a hyperlink to that in depth information directly in your VI. Perhaps you want to put your logo along with a link to your website at the top level of your source code. Whatever the reason, you need to be able to add a normal comment to the block diagram and populate that comment with text and hyperlinks.
As a extension, this new comment field could even take simple html tags for more formatting, embedding images, or maybe even an embedded video.
Message Edited by Rick K on 09-17-2009 12:06 PM
I've had enough!  Your code does not have to look like this:
Or this:
You don't have to wire a string into Build Path's second input!  It can take a relative path just fine!  This is particularly helpful when building relative paths that involve climbing a directory structure.  But it's also useful for building hard-coded folder paths, or even just specifying a file name:
I've seen code that looks like the first two images way too often, so I propose the following:
  • Change the name of the second input of the Build Path function to 'relative path or name'.
  • Change the default data type of this input (i.e. what it looks like when unwired) to path instead of string.
The function will still work fine with string inputs (so existing code is fine), but this approach encourages developers to actually use the path data type when working with paths. You should kudo this idea if you have ever (1) written code that looks like the first two images, (2) needed to explain to someone that they can wire a path into Build Path's second input, or (3) gotten burned by multi-platform issues when somebody typed path separators into a string wired into Build Path.
I have a rather large string indicator for displaying operator messages/alarms
and I would like to have the option for an automatic vertical center of the text,
so that all messages get displayed in the center of the screen (if too many lines, justify to top and display the scrollbar).
I also have a 2 line statusbar, but displaying a 1 line message that is not vertically centered, looks very strange.
The work-around I'm using now is to display the multiline string centered in a picturecontrol,
but I'm not a big fan of this fix because there are many boundary-conditions to keep in mind ...
Another annoyance is that to prevent selection of text in the indicator I often disable the indicator
(it looks unprofessional if an indicatortext can be selected in the GUI),
but if the displayed text is larger than the string indicator, the scrollbar is also disabled !?!?
and therefore not controllable by the user
All events have optional event terminals on the left. Signaling events also have e.g. a "discard?" terminal on the right.
Hovering over them with the mouse does not generate any relevant context help, and maybe it should. (well, there is a tip string that simply duplicates what is already written on the terminal giving boring redundant information).
I suggest that hovering over an event terminal with the context help open should first of all tell us how these terminals are called in general ("Event Data Node", according to the help, but who knows that???), but also give specific information about each terminal under the cursor.
For example:
  • if I hover over the "discard?" terminal, it could tell me that wiring a TRUE would ignore the event, etc.
  • if I hover over the "Ctlref" terminal, it could tell me that it outputs a control reference of the control that fired the event
  • if I hover over the "type" terminal, it could tell me a list of possible types and what they mean.
  • etc.
IDEA: I suggest to add relevant context help to all event data nodes. Thanks!
(Note that e.g. the "timed loop" terminal already have context help. This should be similar)
(This is an idea related to Jack's idea here, which however deals with "reshape array".)
When using "built array" with parts that are mismatched in lenght, the largest input wins and the rest are padded with the default value for the given datatype (zero for numerics). This is often not desirable, for example when graphing multiple plots.
Padding with zero causes extra data (zeroes) to show on the graph that did not exist in the original wires. A more desirable option here would be to pad with NaN so only actual data is graphed.
My suggestion is to add an optional input to "built array" that allows defining the pad value is case the inputs are mismatched.
Here is an example how it could look like. (of course the icon would probably need to change a little)
This has been discussed in various places like here, but I couldn't find an idea for it...
There are quite a few LabVIEW primitives which will always run, even if presented with an error on the "error in" terminal. Common examples are "Close Reference" and "Close File".
What would be really useful is to have some kind of visual indication of this behaviour. Ideally this would be a simple marking on the VI icon which could be easily replicated by LV users when we create such VIs ourselves. (It could possibly even be an option in the icon editor!)
Currently the only indication that a VI will run on error is this discrete line in the VI help:
I believe a visual indicator would be much more fitting for LabVIEW as a visual language, and would make this behaviour far more obvious to LabVIEW users.
This is a very small suggestion, and hopefully easy to implement.  When wires cross, very often one of the wires involved is an Error wire, and as it is usually wired last, it sits on top of all the other wires.  All I'm asking is that Error wires are always placed underneath all other wires when they are created.  To my mind, this improves the readability of the diagram.
What would help further is if Error wires were "faded", as if they were 50% transparent.  You do need to be able to see them, but not such that they stand out.  But I'm much less certain that such a change could happen.  The khaki color is an improvement on the old pink though, that's for sure!
Add new features, flexibility, and new controls to the Front Panel.  The only new controls I've seen were made by LabVIEW Customers, and although they were great, they were not resizeable without being distorted (bitmap).  I think it's time for NI to give more options and features for the Front Panel Controls.  I attached some suggestions.  They are there for example, so don't focus on the controls I've made, but the idea of improvements I am suggesting.  NI has done a great job on the Diagrams.  I should hope it's time NI improves the Front Panel.
Suggestions
I would like to have the ability to make a Front Panel background transparent without making the whole window transparent (where the later is currently possible through property nodes).  This one item would expand the UI possibilities.  It would allow for the creation of Front Panels that seem to be borderless similar to many splash screens, about screens, and gadgets.  Below are some industry examples:
Adobe Splash Screen (No border, has shadow, not square)
  Microsoft Word 2010 Splash Screen (No border, rounded corners)
 Resource Meter Windows Gadget (No border, specialized graphic)
Windows Media Center Gadget (Empty-transparent space between two UI elements)
Have you ever placed a background image on your front panel to make it look good, but then found that most of the controls and indicators covered everything up?
Ever wish LabVIEW had more appearance customization to make better looking GUIs?
I would like to propose an opacity slider control in the appearance settings tab of front panel object properties. The added setting would not make the entire objects opacity change; ideally the opacity control would only affect the borders and grey space. With this added control users can make better looking user interfaces without having to make custom controls.
Take a look at the difference:
Not Ideal Front Panel with background image and NO Opacity Control
Beautiful Front Panel with background image that you can still see by setting Opacity Control to 50%
Before and After Appearance Settings tab in the Properties Window for a waveform graph:
Currently the only easy way to implement a similar type of setting is go fully transparent by using the tools palette paintbrush tool and setting the color to transparent:
Kudos and share this idea if you want it to happen!
i propose to add a "Key Focus" event for each control. We already have Mouse events (leaving, entering) - but when the user (or the programmer) prefers the keyboard (with proper tabbing setup) you have to poll each interesting control for it's "Key Focus" property to initiate a user event...
So please:
Add a "Got Focus" (and additionally a "Lost Focus") event to the event structure!
The State Diagram Editor was a very cool tool and lots of LabVIEW users (not only beginners, far from!) are missing it!
And no, the state chart module is not a replacement for the State Diagram Editor!
Discussion here.
Image borowed from Ben
This recent idea reminded me of something I have wanted for quite some time now:  the ability to determine if a property is read or write based on wiring, not some half-buried option in the right-click menu.
The basic idea is simple:  all properties have two terminals, one for writing and one for reading (except read-only of course).  No right-clicking, just wire up the direction you want.
The bottom case is a bit interesting.  I see a few possibilities:
1.  Passthrough (cosmetically saves branching, crossing, etc.) Same behaviour regardless of errors.
2.  Read then write : returns previous value.  What happens if there is an error?  Passthrough, old value?
3. Write then read: almost always passthrough.  In case of error would it return old (ie. actual value) or passthrough?
4. Do not allow this.
I would expect it to perform the write and then the read (3) or passthrough (1).  What is more important to me is the actual value and not the intended value.  Mentally I just see data flowing into then out of the PN when both are wired.
Bottom line:  I see no reason not to permit the wiring to determine read or write of a property.
If there is a cop-out lack of consensus and simultaneous connections are not allowed, I would at least ask for a keyboard modifier (say shift) such that I can shift-drag to expand the PN and get the same property repeated instead of going down the list.  Then I could at least do the write+read with a lot less mouse movement.
When working in LabVIEW in low light conditions, it would be nice to be able to have a quick way to switch to a dark mode, where the default block diagram colour would be a mid-dark-grey.
I would like the ability to enter simple equations in numeric controls and constants. Pressing return places the answer in the control or constant.
I propose that Case Selectors should accept any type of reference, and the two cases generated are "Valid Ref" and "Invalid Ref". (This would be very similar to the current behavior of the Case Selector accepting errors with the two cases of "Error" and "No Error".)
The current behavior using "Not a Number/Path/Refnum" is very unintuitive. It requires the programmer to use Not Logic (i.e., do something if the reference is "not not valid").
