LabVIEW Interface for Arduino Discussions
Error compiling LIFA_Base.ino for Labview 2012
Hello!
I am willing to use Labview with Arduino but I'm trying to compile the last firmware LIFA_Base.ino an I have some errors that I can't understand.
I have been reading the different problems in relation with this in this forum but I understand that I am not the only one with this problem and there is no solution.
What can I do? Can anyone help me please? Is maybe a programming bug of the firmware?
The versions are:
- Labview 2012
- LabVIEW Interface for Arduino v2.2.0.79 by National Instruments
-Arduino 1.0.3 working perfectly with Arduino uno R3.
Error compiling:
LIFA_Base\AccelStepper.cpp.o: In function `AccelStepper::distanceToGo()':
C:\utilidades\arduino-1.0.3-windows\arduino-1.0.3\libraries\LIFA_Base/AccelStepper.cpp:72: multiple definition of `AccelStepper::distanceToGo()'
AccelStepper.cpp.o:C:\DOCUME~1\carla\CONFIG~1\Temp\build4778707117074552561.tmp/AccelStepper.cpp:72: first defined here
LIFA_Base\AccelStepper.cpp.o: In function `AccelStepper::targetPosition()':
C:\utilidades\arduino-1.0.3-windows\arduino-1.0.3\libraries\LIFA_Base/AccelStepper.cpp:77: multiple definition of `AccelStepper::targetPosition()'
AccelStepper.cpp.o:C:\DOCUME~1\carla\CONFIG~1\Temp\build4778707117074552561.tmp/AccelStepper.cpp:77: first defined here
LIFA_Base\AccelStepper.cpp.o: In function `AccelStepper::currentPosition()':
C:\utilidades\arduino-1.0.3-windows\arduino-1.0.3\libraries\LIFA_Base/AccelStepper.cpp:82: multiple definition of `AccelStepper::currentPosition()'
AccelStepper.cpp.o:C:\DOCUME~1\carla\CONFIG~1\Temp\build4778707117074552561.tmp/AccelStepper.cpp:82: first defined here
...and more similar errors....
Thanks in advance. Hoping to get some good news.
Message 1 of 40
(24,842 Views)
Make sure that all the files that are open in the Arduino IDE are unique (meaning that none of the files are opened twice or none of the files have the same content).
Message 2 of 40
(9,145 Views)
Accepted by sc_labview
sc_duino,
The error you are seeing basically means the same thing is defined in two places.  This can happen if you accidentally include a library twice, or if you try to define the same variable or function twice.  Most libraries should have double include protection but not all do.
In addition to Nathan's suggestion above check to see if you have AccelStepper.cpp in your <arduino>/libraries.  If you do try removing it from that directory temporarily to see if it removes the problem.
Let us know if that helps.
-Sam K
LIFA Developer
Message 3 of 40
(9,145 Views)
Thanks a lot!
I just move the folder LIFA_Base to another folder in Mydocuments/Arduino/LIFA_Base and then it compiles without any error.
I am enjoying working with Arduino examples! All works fine!
Santi
Message 4 of 40
(9,145 Views)
Santi,
I'm glad to hear that you were able to get everything up and running.
-Sam K
LIFA Developer
Message 5 of 40
(9,145 Views)
I have the same Problem with the lifa_base program.
I can´t compile the lifa_base.cpp.
It makes same erros:
LIFA_Base.cpp.o: In function `loop':
D:\Programme\arduino-1.0.4-windows\arduino-1.0.4/LIFA_Base.ino:59: undefined reference to `checkForCommand()'
D:\Programme\arduino-1.0.4-windows\arduino-1.0.4/LIFA_Base.ino:65: undefined reference to `sampleContinously()'
LIFA_Base.cpp.o: In function `setup':
D:\Programme\arduino-1.0.4-windows\arduino-1.0.4/LIFA_Base.ino:39: undefined reference to `syncLV()'
Have anyone a solutions for me?
Message 6 of 40
(9,145 Views)
First off, there is no file called LIFA_Base.cpp.  The file should be LIFA_Base.ino.
When you see those errors it means that you did not open the entire project in the Arduino IDE.  I.e. the IDE only opened the one file or failed to open all the files.
Make sure that you have all files [that are in the LIFA_Base folder] open in the Arduino IDE before trying to compile.
Message 7 of 40
(9,145 Views)
Okay I open the Lifa_base.ino on Arduino IDE with all files. But now i become a after error messange, like:
LIFA_Base\AFMotor.cpp.o: In function `AFMotorController':
D:\Programme\arduino-1.0.4-windows\arduino-1.0.4\libraries\LIFA_Base/AFMotor.cpp:24: multiple definition of `AFMotorController::AFMotorController()'
AFMotor.cpp.o:C:\Users\Admin\AppData\Local\Temp\build8346374308204063085.tmp/AFMotor.cpp:24: first defined here
d:/programme/arduino-1.0.4-windows/arduino-1.0.4/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/../../../../avr/bin/ld.exe: Disabling relaxation: it will not work with multiple definitions
LIFA_Base\AFMotor.cpp.o: In function `AF_DCMotor::setSpeed(unsigned char)':
D:\Programme\arduino-1.0.4-windows\arduino-1.0.4\libraries\LIFA_Base/AFMotor.cpp:298: multiple definition of `AF_DCMotor::setSpeed(unsigned char)'
AFMotor.cpp.o:C:\Users\Admin\AppData\Local\Temp\build8346374308204063085.tmp/AFMotor.cpp:298: first defined here
LIFA_Base\AFMotor.cpp.o: In function `AF_Stepper::setSpeed(unsigned int)':
D:\Programme\arduino-1.0.4-windows\arduino-1.0.4\libraries\LIFA_Base/AFMotor.cpp:359: multiple definition of `AF_Stepper::setSpeed(unsigned int)'
AFMotor.cpp.o:C:\Users\Admin\AppData\Local\Temp\build8346374308204063085.tmp/AFMotor.cpp:359: first defined here
LIFA_Base\AFMotor.cpp.o: In function `AFMotorController::latch_tx()':
D:\Programme\arduino-1.0.4-windows\arduino-1.0.4\libraries\LIFA_Base/AFMotor.cpp:48: multiple definition of `AFMotorController::latch_tx()'
AFMotor.cpp.o:C:\Users\Admin\AppData\Local\Temp\build8346374308204063085.tmp/AFMotor.cpp:48: first defined here
LIFA_Base\AFMotor.cpp.o: In function `AF_Stepper::onestep(unsigned char, unsigned char)':
D:\Programme\arduino-1.0.4-windows\arduino-1.0.4\libraries\LIFA_Base/AFMotor.cpp:413: multiple definition of `AF_Stepper::onestep(unsigned char, unsigned char)'
AFMotor.cpp.o:C:\Users\Admin\AppData\Local\Temp\build8346374308204063085.tmp/AFMotor.cpp:413: first defined here
LIFA_Base\AFMotor.cpp.o:(.data.microstepcurve+0x0): multiple definition of `microstepcurve'
AFMotor.cpp.o:(.data.microstepcurve+0x0): first defined here
LIFA_Base\AFMotor.cpp.o: In function `AF_Stepper::step(unsigned int, unsigned char, unsigned char)':
D:\Programme\arduino-1.0.4-windows\arduino-1.0.4\libraries\LIFA_Base/AFMotor.cpp:376: multiple definition of `AF_Stepper::step(unsigned int, unsigned char, unsigned char)'
AFMotor.cpp.o:C:\Users\Admin\AppData\Local\Temp\build8346374308204063085.tmp/AFMotor.cpp:376: first defined here
LIFA_Base\AFMotor.cpp.o: In function `AF_Stepper::release()':
D:\Programme\arduino-1.0.4-windows\arduino-1.0.4\libraries\LIFA_Base/AFMotor.cpp:365: multiple definition of `AF_Stepper::release()'
AFMotor.cpp.o:C:\Users\Admin\AppData\Local\Temp\build8346374308204063085.tmp/AFMotor.cpp:365: first defined here
LIFA_Base\AFMotor.cpp.o: In function `AF_DCMotor::run(unsigned char)':
D:\Programme\arduino-1.0.4-windows\arduino-1.0.4\libraries\LIFA_Base/AFMotor.cpp:264: multiple definition of `AF_DCMotor::run(unsigned char)'
AFMotor.cpp.o:C:\Users\Admin\AppData\Local\Temp\build8346374308204063085.tmp/AFMotor.cpp:264: first defined here
LIFA_Base\AFMotor.cpp.o: In function `AFMotorController::enable()':
D:\Programme\arduino-1.0.4-windows\arduino-1.0.4\libraries\LIFA_Base/AFMotor.cpp:26: multiple definition of `AFMotorController::enable()'
AFMotor.cpp.o:C:\Users\Admin\AppData\Local\Temp\build8346374308204063085.tmp/AFMotor.cpp:26: first defined here
LIFA_Base\AFMotor.cpp.o: In function `AF_DCMotor':
D:\Programme\arduino-1.0.4-windows\arduino-1.0.4\libraries\LIFA_Base/AFMotor.cpp:234: multiple definition of `AF_DCMotor::AF_DCMotor(unsigned char, unsigned char)'
AFMotor.cpp.o:C:\Users\Admin\AppData\Local\Temp\build8346374308204063085.tmp/AFMotor.cpp:234: first defined here
LIFA_Base\AFMotor.cpp.o: In function `AF_Stepper':
D:\Programme\arduino-1.0.4-windows\arduino-1.0.4\libraries\LIFA_Base/AFMotor.cpp:315: multiple definition of `AF_Stepper::AF_Stepper(unsigned int, unsigned char)'
AFMotor.cpp.o:C:\Users\Admin\AppData\Local\Temp\build8346374308204063085.tmp/AFMotor.cpp:315: first defined here
LIFA_Base\IRremote.cpp.o: In function `IRrecv':
D:\Programme\arduino-1.0.4-windows\arduino-1.0.4\libraries\LIFA_Base/IRremote.cpp:217: multiple definition of `IRrecv::IRrecv(int)'
IRremote.cpp.o:C:\Users\Admin\AppData\Local\Temp\build8346374308204063085.tmp/IRremote.cpp:217: first defined here
D:\Programme\arduino-1.0.4-windows\arduino-1.0.4\libraries\LIFA_Base/IRremote.cpp:217: multiple definition of `irparams'
LIFA_Base\IRremote.cpp.o: In function `IRrecv::resume()':
D:\Programme\arduino-1.0.4-windows\arduino-1.0.4\libraries\LIFA_Base/IRremote.cpp:332: multiple definition of `IRrecv::resume()'
IRremote.cpp.o:C:\Users\Admin\AppData\Local\Temp\build8346374308204063085.tmp/IRremote.cpp:332: first defined here
LIFA_Base\IRremote.cpp.o: In function `IRrecv::decodeNEC(decode_results*)':
D:\Programme\arduino-1.0.4-windows\arduino-1.0.4\libraries\LIFA_Base/IRremote.cpp:383: multiple definition of `IRrecv::decodeNEC(decode_results*)'
IRremote.cpp.o:C:\Users\Admin\AppData\Local\Temp\build8346374308204063085.tmp/IRremote.cpp:383: first defined here
LIFA_Base\IRremote.cpp.o: In function `IRrecv::decodeSony(decode_results*)':
D:\Programme\arduino-1.0.4-windows\arduino-1.0.4\libraries\LIFA_Base/IRremote.cpp:431: multiple definition of `IRrecv::decodeSony(decode_results*)'
IRremote.cpp.o:C:\Users\Admin\AppData\Local\Temp\build8346374308204063085.tmp/IRremote.cpp:431: first defined here
LIFA_Base\IRremote.cpp.o: In function `IRrecv::getRClevel(decode_results*, int*, int*, int)':
D:\Programme\arduino-1.0.4-windows\arduino-1.0.4\libraries\LIFA_Base/IRremote.cpp:478: multiple definition of `IRrecv::getRClevel(decode_results*, int*, int*, int)'
IRremote.cpp.o:C:\Users\Admin\AppData\Local\Temp\build8346374308204063085.tmp/IRremote.cpp:478: first defined here
LIFA_Base\IRremote.cpp.o: In function `IRrecv::decodeRC5(decode_results*)':
D:\Programme\arduino-1.0.4-windows\arduino-1.0.4\libraries\LIFA_Base/IRremote.cpp:517: multiple definition of `IRrecv::decodeRC5(decode_results*)'
IRremote.cpp.o:C:\Users\Admin\AppData\Local\Temp\build8346374308204063085.tmp/IRremote.cpp:517: first defined here
LIFA_Base\IRremote.cpp.o: In function `IRrecv::decodeRC6(decode_results*)':
D:\Programme\arduino-1.0.4-windows\arduino-1.0.4\libraries\LIFA_Base/IRremote.cpp:552: multiple definition of `IRrecv::decodeRC6(decode_results*)'
IRremote.cpp.o:C:\Users\Admin\AppData\Local\Temp\build8346374308204063085.tmp/IRremote.cpp:552: first defined here
LIFA_Base\IRremote.cpp.o: In function `IRrecv::decode(decode_results*)':
D:\Programme\arduino-1.0.4-windows\arduino-1.0.4\libraries\LIFA_Base/IRremote.cpp:341: multiple definition of `IRrecv::decode(decode_results*)'
IRremote.cpp.o:C:\Users\Admin\AppData\Local\Temp\build8346374308204063085.tmp/IRremote.cpp:341: first defined here
LIFA_Base\IRremote.cpp.o: In function `__vector_15':
D:\Programme\arduino-1.0.4-windows\arduino-1.0.4\libraries\LIFA_Base/IRremote.cpp:264: multiple definition of `__vector_15'
IRremote.cpp.o:C:\Users\Admin\AppData\Local\Temp\build8346374308204063085.tmp/IRremote.cpp:264: first defined here
LIFA_Base\IRremote.cpp.o: In function `IRrecv::blink13(int)':
D:\Programme\arduino-1.0.4-windows\arduino-1.0.4\libraries\LIFA_Base/IRremote.cpp:252: multiple definition of `IRrecv::blink13(int)'
IRremote.cpp.o:C:\Users\Admin\AppData\Local\Temp\build8346374308204063085.tmp/IRremote.cpp:252: first defined here
LIFA_Base\IRremote.cpp.o: In function `IRrecv::enableIRIn()':
D:\Programme\arduino-1.0.4-windows\arduino-1.0.4\libraries\LIFA_Base/IRremote.cpp:224: multiple definition of `IRrecv::enableIRIn()'
IRremote.cpp.o:C:\Users\Admin\AppData\Local\Temp\build8346374308204063085.tmp/IRremote.cpp:224: first defined here
LIFA_Base\IRremote.cpp.o: In function `IRsend::enableIROut(int)':
D:\Programme\arduino-1.0.4-windows\arduino-1.0.4\libraries\LIFA_Base/IRremote.cpp:184: multiple definition of `IRsend::enableIROut(int)'
IRremote.cpp.o:C:\Users\Admin\AppData\Local\Temp\build8346374308204063085.tmp/IRremote.cpp:184: first defined here
LIFA_Base\IRremote.cpp.o: In function `IRsend::space(int)':
D:\Programme\arduino-1.0.4-windows\arduino-1.0.4\libraries\LIFA_Base/IRremote.cpp:177: multiple definition of `IRsend::space(int)'
IRremote.cpp.o:C:\Users\Admin\AppData\Local\Temp\build8346374308204063085.tmp/IRremote.cpp:177: first defined here
LIFA_Base\IRremote.cpp.o: In function `IRsend::mark(int)':
D:\Programme\arduino-1.0.4-windows\arduino-1.0.4\libraries\LIFA_Base/IRremote.cpp:169: multiple definition of `IRsend::mark(int)'
IRremote.cpp.o:C:\Users\Admin\AppData\Local\Temp\build8346374308204063085.tmp/IRremote.cpp:169: first defined here
LIFA_Base\IRremote.cpp.o: In function `IRsend::sendRC6(unsigned long, int)':
D:\Programme\arduino-1.0.4-windows\arduino-1.0.4\libraries\LIFA_Base/IRremote.cpp:138: multiple definition of `IRsend::sendRC6(unsigned long, int)'
IRremote.cpp.o:C:\Users\Admin\AppData\Local\Temp\build8346374308204063085.tmp/IRremote.cpp:138: first defined here
LIFA_Base\IRremote.cpp.o: In function `IRsend::sendRC5(unsigned long, int)':
D:\Programme\arduino-1.0.4-windows\arduino-1.0.4\libraries\LIFA_Base/IRremote.cpp:116: multiple definition of `IRsend::sendRC5(unsigned long, int)'
IRremote.cpp.o:C:\Users\Admin\AppData\Local\Temp\build8346374308204063085.tmp/IRremote.cpp:116: first defined here
LIFA_Base\IRremote.cpp.o: In function `IRsend::sendRaw(unsigned int*, int, int)':
D:\Programme\arduino-1.0.4-windows\arduino-1.0.4\libraries\LIFA_Base/IRremote.cpp:101: multiple definition of `IRsend::sendRaw(unsigned int*, int, int)'
IRremote.cpp.o:C:\Users\Admin\AppData\Local\Temp\build8346374308204063085.tmp/IRremote.cpp:101: first defined here
LIFA_Base\IRremote.cpp.o: In function `IRsend::sendSony(unsigned long, int)':
D:\Programme\arduino-1.0.4-windows\arduino-1.0.4\libraries\LIFA_Base/IRremote.cpp:83: multiple definition of `IRsend::sendSony(unsigned long, int)'
IRremote.cpp.o:C:\Users\Admin\AppData\Local\Temp\build8346374308204063085.tmp/IRremote.cpp:83: first defined here
LIFA_Base\IRremote.cpp.o: In function `IRsend::sendNEC(unsigned long, int)':
D:\Programme\arduino-1.0.4-windows\arduino-1.0.4\libraries\LIFA_Base/IRremote.cpp:63: multiple definition of `IRsend::sendNEC(unsigned long, int)'
IRremote.cpp.o:C:\Users\Admin\AppData\Local\Temp\build8346374308204063085.tmp/IRremote.cpp:63: first defined here
D:\Programme\arduino-1.0.4-windows\arduino-1.0.4\libraries\LIFA_Base/AccelStepper.cpp:72: multiple definition of `AccelStepper::distanceToGo()'
AccelStepper.cpp.o:C:\Users\Admin\AppData\Local\Temp\build8346374308204063085.tmp/AccelStepper.cpp:72: first defined here
D:\Programme\arduino-1.0.4-windows\arduino-1.0.4\libraries\LIFA_Base/AccelStepper.cpp:77: multiple definition of `AccelStepper::targetPosition()'
AccelStepper.cpp.o:C:\Users\Admin\AppData\Local\Temp\build8346374308204063085.tmp/AccelStepper.cpp:77: first defined here
D:\Programme\arduino-1.0.4-windows\arduino-1.0.4\libraries\LIFA_Base/AccelStepper.cpp:82: multiple definition of `AccelStepper::currentPosition()'
AccelStepper.cpp.o:C:\Users\Admin\AppData\Local\Temp\build8346374308204063085.tmp/AccelStepper.cpp:82: first defined here
LIFA_Base\AccelStepper.cpp.o: In function `AccelStepper':
D:\Programme\arduino-1.0.4-windows\arduino-1.0.4\libraries\LIFA_Base/AccelStepper.cpp:204: multiple definition of `AccelStepper::AccelStepper(void (*)(), void (*)())'
AccelStepper.cpp.o:C:\Users\Admin\AppData\Local\Temp\build8346374308204063085.tmp/AccelStepper.cpp:204: first defined here
LIFA_Base\AccelStepper.cpp.o: In function `AccelStepper::setSpeed(float)':
D:\Programme\arduino-1.0.4-windows\arduino-1.0.4\libraries\LIFA_Base/AccelStepper.cpp:236: multiple definition of `AccelStepper::setSpeed(float)'
AccelStepper.cpp.o:C:\Users\Admin\AppData\Local\Temp\build8346374308204063085.tmp/AccelStepper.cpp:236: first defined here
LIFA_Base\AccelStepper.cpp.o: In function `AccelStepper::computeNewSpeed()':
D:\Programme\arduino-1.0.4-windows\arduino-1.0.4\libraries\LIFA_Base/AccelStepper.cpp:94: multiple definition of `AccelStepper::computeNewSpeed()'
AccelStepper.cpp.o:C:\Users\Admin\AppData\Local\Temp\build8346374308204063085.tmp/AccelStepper.cpp:94: first defined here
LIFA_Base\AccelStepper.cpp.o: In function `AccelStepper::setAcceleration(float)':
D:\Programme\arduino-1.0.4-windows\arduino-1.0.4\libraries\LIFA_Base/AccelStepper.cpp:230: multiple definition of `AccelStepper::setAcceleration(float)'
AccelStepper.cpp.o:C:\Users\Admin\AppData\Local\Temp\build8346374308204063085.tmp/AccelStepper.cpp:230: first defined here
LIFA_Base\AccelStepper.cpp.o: In function `AccelStepper::setMaxSpeed(float)':
D:\Programme\arduino-1.0.4-windows\arduino-1.0.4\libraries\LIFA_Base/AccelStepper.cpp:224: multiple definition of `AccelStepper::setMaxSpeed(float)'
AccelStepper.cpp.o:C:\Users\Admin\AppData\Local\Temp\build8346374308204063085.tmp/AccelStepper.cpp:224: first defined here
LIFA_Base\AccelStepper.cpp.o: In function `AccelStepper::setCurrentPosition(long)':
D:\Programme\arduino-1.0.4-windows\arduino-1.0.4\libraries\LIFA_Base/AccelStepper.cpp:88: multiple definition of `AccelStepper::setCurrentPosition(long)'
AccelStepper.cpp.o:C:\Users\Admin\AppData\Local\Temp\build8346374308204063085.tmp/AccelStepper.cpp:88: first defined here
LIFA_Base\AccelStepper.cpp.o: In function `AccelStepper::moveTo(long)':
D:\Programme\arduino-1.0.4-windows\arduino-1.0.4\libraries\LIFA_Base/AccelStepper.cpp:14: multiple definition of `AccelStepper::moveTo(long)'
AccelStepper.cpp.o:C:\Users\Admin\AppData\Local\Temp\build8346374308204063085.tmp/AccelStepper.cpp:14: first defined here
LIFA_Base\AccelStepper.cpp.o: In function `AccelStepper::move(long)':
D:\Programme\arduino-1.0.4-windows\arduino-1.0.4\libraries\LIFA_Base/AccelStepper.cpp:20: multiple definition of `AccelStepper::move(long)'
AccelStepper.cpp.o:C:\Users\Admin\AppData\Local\Temp\build8346374308204063085.tmp/AccelStepper.cpp:20: first defined here
LIFA_Base\AccelStepper.cpp.o: In function `AccelStepper::speed()':
D:\Programme\arduino-1.0.4-windows\arduino-1.0.4\libraries\LIFA_Base/AccelStepper.cpp:251: multiple definition of `AccelStepper::speed()'
AccelStepper.cpp.o:C:\Users\Admin\AppData\Local\Temp\build8346374308204063085.tmp/AccelStepper.cpp:251: first defined here
LIFA_Base\AccelStepper.cpp.o: In function `AccelStepper::step(unsigned char)':
D:\Programme\arduino-1.0.4-windows\arduino-1.0.4\libraries\LIFA_Base/AccelStepper.cpp:257: multiple definition of `AccelStepper::step(unsigned char)'
AccelStepper.cpp.o:C:\Users\Admin\AppData\Local\Temp\build8346374308204063085.tmp/AccelStepper.cpp:257: first defined here
LIFA_Base\AccelStepper.cpp.o: In function `AccelStepper::step0()':
D:\Programme\arduino-1.0.4-windows\arduino-1.0.4\libraries\LIFA_Base/AccelStepper.cpp:283: multiple definition of `AccelStepper::step0()'
AccelStepper.cpp.o:C:\Users\Admin\AppData\Local\Temp\build8346374308204063085.tmp/AccelStepper.cpp:283: first defined here
LIFA_Base\AccelStepper.cpp.o: In function `AccelStepper::setMinPulseWidth(unsigned int)':
D:\Programme\arduino-1.0.4-windows\arduino-1.0.4\libraries\LIFA_Base/AccelStepper.cpp:466: multiple definition of `AccelStepper::setMinPulseWidth(unsigned int)'
AccelStepper.cpp.o:C:\Users\Admin\AppData\Local\Temp\build8346374308204063085.tmp/AccelStepper.cpp:466: first defined here
LIFA_Base\AccelStepper.cpp.o: In function `AccelStepper::enableOutputs()':
D:\Programme\arduino-1.0.4-windows\arduino-1.0.4\libraries\LIFA_Base/AccelStepper.cpp:451: multiple definition of `AccelStepper::enableOutputs()'
AccelStepper.cpp.o:C:\Users\Admin\AppData\Local\Temp\build8346374308204063085.tmp/AccelStepper.cpp:451: first defined here
D:\Programme\arduino-1.0.4-windows\arduino-1.0.4\libraries\LIFA_Base/AccelStepper.cpp:181: multiple definition of `AccelStepper::AccelStepper(unsigned char, unsigned char, unsigned char, unsigned char, unsigned char)'
AccelStepper.cpp.o:C:\Users\Admin\AppData\Local\Temp\build8346374308204063085.tmp/AccelStepper.cpp:181: first defined here
LIFA_Base\AccelStepper.cpp.o: In function `AccelStepper::disableOutputs()':
D:\Programme\arduino-1.0.4-windows\arduino-1.0.4\libraries\LIFA_Base/AccelStepper.cpp:438: multiple definition of `AccelStepper::disableOutputs()'
AccelStepper.cpp.o:C:\Users\Admin\AppData\Local\Temp\build8346374308204063085.tmp/AccelStepper.cpp:438: first defined here
LIFA_Base\AccelStepper.cpp.o: In function `AccelStepper::step8(unsigned char)':
D:\Programme\arduino-1.0.4-windows\arduino-1.0.4\libraries\LIFA_Base/AccelStepper.cpp:375: multiple definition of `AccelStepper::step8(unsigned char)'
AccelStepper.cpp.o:C:\Users\Admin\AppData\Local\Temp\build8346374308204063085.tmp/AccelStepper.cpp:375: first defined here
LIFA_Base\AccelStepper.cpp.o: In function `AccelStepper::step4(unsigned char)':
D:\Programme\arduino-1.0.4-windows\arduino-1.0.4\libraries\LIFA_Base/AccelStepper.cpp:337: multiple definition of `AccelStepper::step4(unsigned char)'
AccelStepper.cpp.o:C:\Users\Admin\AppData\Local\Temp\build8346374308204063085.tmp/AccelStepper.cpp:337: first defined here
LIFA_Base\AccelStepper.cpp.o: In function `AccelStepper::step2(unsigned char)':
D:\Programme\arduino-1.0.4-windows\arduino-1.0.4\libraries\LIFA_Base/AccelStepper.cpp:308: multiple definition of `AccelStepper::step2(unsigned char)'
AccelStepper.cpp.o:C:\Users\Admin\AppData\Local\Temp\build8346374308204063085.tmp/AccelStepper.cpp:308: first defined here
LIFA_Base\AccelStepper.cpp.o: In function `AccelStepper::step1(unsigned char)':
D:\Programme\arduino-1.0.4-windows\arduino-1.0.4\libraries\LIFA_Base/AccelStepper.cpp:295: multiple definition of `AccelStepper::step1(unsigned char)'
AccelStepper.cpp.o:C:\Users\Admin\AppData\Local\Temp\build8346374308204063085.tmp/AccelStepper.cpp:295: first defined here
LIFA_Base\AccelStepper.cpp.o: In function `AccelStepper::desiredSpeed()':
D:\Programme\arduino-1.0.4-windows\arduino-1.0.4\libraries\LIFA_Base/AccelStepper.cpp:109: multiple definition of `AccelStepper::desiredSpeed()'
AccelStepper.cpp.o:C:\Users\Admin\AppData\Local\Temp\build8346374308204063085.tmp/AccelStepper.cpp:109: first defined here
LIFA_Base\AccelStepper.cpp.o: In function `AccelStepper::runSpeed()':
D:\Programme\arduino-1.0.4-windows\arduino-1.0.4\libraries\LIFA_Base/AccelStepper.cpp:28: multiple definition of `AccelStepper::runSpeed()'
AccelStepper.cpp.o:C:\Users\Admin\AppData\Local\Temp\build8346374308204063085.tmp/AccelStepper.cpp:28: first defined here
LIFA_Base\AccelStepper.cpp.o: In function `AccelStepper::runSpeedToPosition()':
D:\Programme\arduino-1.0.4-windows\arduino-1.0.4\libraries\LIFA_Base/AccelStepper.cpp:476: multiple definition of `AccelStepper::runSpeedToPosition()'
AccelStepper.cpp.o:C:\Users\Admin\AppData\Local\Temp\build8346374308204063085.tmp/AccelStepper.cpp:476: first defined here
LIFA_Base\AccelStepper.cpp.o: In function `AccelStepper::run()':
D:\Programme\arduino-1.0.4-windows\arduino-1.0.4\libraries\LIFA_Base/AccelStepper.cpp:171: multiple definition of `AccelStepper::run()'
AccelStepper.cpp.o:C:\Users\Admin\AppData\Local\Temp\build8346374308204063085.tmp/AccelStepper.cpp:171: first defined here
LIFA_Base\AccelStepper.cpp.o: In function `AccelStepper::runToPosition()':
D:\Programme\arduino-1.0.4-windows\arduino-1.0.4\libraries\LIFA_Base/AccelStepper.cpp:470: multiple definition of `AccelStepper::runToPosition()'
AccelStepper.cpp.o:C:\Users\Admin\AppData\Local\Temp\build8346374308204063085.tmp/AccelStepper.cpp:470: first defined here
LIFA_Base\AccelStepper.cpp.o: In function `AccelStepper::runToNewPosition(long)':
D:\Programme\arduino-1.0.4-windows\arduino-1.0.4\libraries\LIFA_Base/AccelStepper.cpp:482: multiple definition of `AccelStepper::runToNewPosition(long)'
AccelStepper.cpp.o:C:\Users\Admin\AppData\Local\Temp\build8346374308204063085.tmp/AccelStepper.cpp:482: first defined here
Message 8 of 40
(9,145 Views)
We have now come full circle on this thread.  See post 1 (it's the same errors).
Message 9 of 40
(9,145 Views)
Thanks!!!
Message 10 of 40
(9,145 Views)
