LabVIEW Public Beta Program in 2025
Context help kills LabVIEW if hovering over a missing VI!
So I was looking at this VI here And was hovering over one of the missing VIs (no drivers installed here).
  1. If I hover over the missing VI and press ctrl+h, LabVIEW disappears instantly.
  2. If I press ctrl+h first, the context help appears, but If I now move the mouse over the missing VI, LabVIEW again quits. Poof!!!
100% Reproducible, tried 4 times. Ouch! Same for all other missing VIs I tried.
Message 1 of 9
(1,386 Views)
I cannot reproduce the crash in LabVIEW 2025 Q1 Patch 1 64-bit. The Context Help window displays properly with the missing VI information in both the scenarios you describe.
Message 2 of 9
(1,354 Views)
This is the beta forum and I am running 2025 Q3 (64bit), 25.3d.186
I would assume this is a new bug, else it would have been reported long ago (guessing).
Message 3 of 9
(1,347 Views)
Hah, sorry for the noise, I thought I was in another forum.
Although I did try the same experiment in the latest beta install (25.3d350 64-bit), and I was unable to see the crash there either.
Message 4 of 9
(1,327 Views)
Thanks. NIPM does not show any updates. Do you have an internal version or can I get it by redownloading?
Message 5 of 9
(1,323 Views)
It's an internal version. I don't think there will be another beta release before the public release, but @Christina_R would know for sure.
Message 6 of 9
(1,321 Views)
So the good news is that they probably fixed it already. 😄
Message 7 of 9
(1,319 Views)
I can confirm this behavior on my beta VM (25.3d.186), so it isn't just your install, at least.  Good to know it doesn't happen in NI's latest version.
Message 8 of 9
(1,313 Views)
I verified that this Bug was introduced in an earlier build of LabVIEW 2025 Q3, and has already been reported internally and fixed. The Bug number is 3079400.
Message 9 of 9
(1,268 Views)
