About NI PCI based Card
Hello Everyone,
I have a doubt that imagine that I'm running my vi which execute some function for  8 hours  for some project  using NI PCI Card, and  I do not touch my pc till the duration completes I have change the pc sleep to never does the vi execute without any problem..??
please let me know I'm new to LabVIEW so
Thanks in Advance
Message 1 of 41
(4,734 Views)
Hi Gowtham,
Usually: Yes!
(Well, your VI should be as bug-free as possible, otherwise there could occur problems independent from sleep mode of the computer…)
Message 2 of 41
(4,705 Views)
Hello Sir,
My Vi has no error, but the problem is when I run the vi the program starts running and I'm playing some music which is 10 hours even I'm displaying the Time but if I return to my pc after the 10 hours the time displayed in the Indicator will be different value like it has the expected Display is 10:50:12(H:M:Sec) but the actual display is like 2350:12:56 something like that please do give me a solution. I have attached the code also.
Message 3 of 41
(4,694 Views)
Two suggestions:
On your waveform graph- change the Time Axis Format to Relative Time
Then replace this mistake:
With your own counter as shown
the iteration terminal STOPS INCREMENTING at 2^31-1
Message 4 of 41
(4,685 Views)
I don't see any Time VIs (except unconnected ones in a Diagram Disable), but I suspect that "Time Arithmetic" is what is bugging you.  LabVIEW's Time Stamp is a little strange, but you can think of it as a "Second" counter.  If you subtract two Time Stamps, you get the time difference in seconds.  Similarly, if you add 10*60*60 to the current time, this represents 10 hours (60 seconds/minute, 60 minutes/hour) and should be the time ten hours from now.
This Snippet (in LabVIEW 2016) shows how to do this.  I've also attached the VI itself.
Bob Schor
Message 5 of 41
(4,681 Views)
Bob Schor
Not really strange, since time is usually defined as "seconds since <INSERT EPOCH TIME HERE>."
Bill
CLD
(Mid-Level minion.)
Message 6 of 41
(4,670 Views)
Hello Sir,
Actually I cant change the Time axis to relative timing because the project is different for which we are using, and I didn't get the second solution...??.
When I run my Vi it has to stop after the end of music but its still not ending and giving me a random display as I discussed earlier
Message 7 of 41
(4,638 Views)
Hello Sir,
Actually I need to count the time because I need to know how many hours has taken to run music, but I didn't get what you were supposed to tell.
Message 8 of 41
(4,637 Views)
Hello sir,
When I came after some time to my PC screen was off when I touch mouse, Monitor gets ON and I saw that random changing value and the error was occurred as follows
Error -200290 occurred at SCL Analog Output Sound File.vi
Possible reason(s):
The generation has stopped to prevent the regeneration of old samples. Your application was unable to write samples to the background buffer fast enough to prevent old samples from being regenerated.
To avoid this error, you can do any of the following:
  1. Increase the size of the background buffer by configuring the buffer.
  2. Increase the number of samples you write each time you invoke a write operation.
  3. Write samples more often.
  4. Reduce the sample rate.
  5. If your data transfer method is interrupts, try using DMA or USB Bulk.
  6. Reduce the number of applications your computer is executing concurrently.
In addition, if you do not need to write every sample that is generated, you can configure the regeneration mode to allow regeneration, and then use the Position and Offset attributes to write the desired samples.
Task Name: _unnamedTask<3>
please suggest me a solution
Message 9 of 41
(4,630 Views)
Do not let your PC go to sleep!  Change the power profile settings from the control panel.  "Sleeping" hardware does not "Do Work".
Message 10 of 41
(4,619 Views)
