About NI PCI based Card
Hello sir,
I have changed the PC sleep to never still happening like that, only the monitor screen go off, and if I highlight the execution the problem occurs same, and one more thing for music file of Duration 20min its working properly but I don't know what exactly happening for 10 hour music please let me any one
Message 11 of 41
(1,557 Views)
How about you providing a little more help to those of us trying to help you?  Attach your (modified?) code!
Bob Schor
Message 12 of 41
(1,550 Views)
Hello sir
I have already uploaded the code , but no problem now I'm again uploading it
Message 13 of 41
(1,547 Views)
You know I'm going to be brutal about that right?
First, you did not apply the changes recommended previously.  You certainly can change the display format on the time axis on the chart on the front panel without changing any other code. IT IS NOT WIRED TO THE CONNECTOR PANE! nor is it a type def ctl file.  Change the display.  then show us what is wrong by showing us the display and telling us what you think it should be.
Next, why do you have trouble understanding that this code will not work?
the i terminal stops incrementing when 2^31-1 iterations or more have occurred! Period! and, that is probably the root of your issue.
  • Learn how to press Ctrl+U
  • Delete the outer case and the Abort VI method in the false case- (LabVIEW Jedi mind trick- You do not need that Abort VI Method)
  • Get rid of the global- that's just advice
Message 14 of 41
(1,542 Views)
Hello sir,
I'm sorry for my mistake that I didn't change the code that is because I thought that, this is not the problem but now I'm going to change it according as u said sir. and one more thing is I don't know that why that I iteration is incrementing randomly..?
Message 15 of 41
(1,533 Views)
Hello Sir
Another reason why I didn't change the code is actually its a sub vi of some project so if I change the graph setting may be it will effect the main vi code so, and can u please let me know again how to change the counter time..?? please
Message 16 of 41
(1,546 Views)
Hello sir,
I was running my vi(old vi not the modified vi)it was about 40mins it was perfectly running, so I wanted to open some excel file so while opening it pc didn't open it and pop up message was unable to open file, at that time I saw the vi that time display was randomly changing and no waveform was displaying on the graph
Message 17 of 41
(1,540 Views)
You are missing a wire on the third function down, fourth from the left ...  Oops, sorry, my mistake, I cannot help you  with a VI that I haven't seen because you haven't posted it.  My Forum Colleague RTSLVU, has an interesting signature that I'm going to "borrow" ...
Bob Schor
Unfortunately, most readers of this Forum, including some real Experts, have not mastered the skill of being able to read the code that Posters fail to post. If we cannot see "what you did wrong", we are unable to tell you how to fix it. (Bob Schor 28 August 2018)
Message 18 of 41
(1,530 Views)
@GowthamRajegowda wrote:
Hello Sir
If it is a sub vi, Why is the connector pane unwired?
Message 19 of 41
(1,527 Views)
Hello sir,
I have uploaded the Vi sir
Message 20 of 41
(1,514 Views)
