About NI PCI based Card
Hi Gowtham,
I have to count the time
You know samplerate  and number of samples, so you can easily calculate the playtime!
For anything else there is ElapsedTime to give you the elapsed time…
can we write 5 different sample files corresponding to each music file separately..??
Yes.
Use a loop to iterate over your 5 files…
Message 31 of 41
(1,824 Views)
hello GerdW sir,
 Is there any Solution to count time..??
Message 32 of 41
(1,820 Views)
Hi Gowtham,
yes.
As written before…
Message 33 of 41
(1,818 Views)
hello GerdW sir,
Ya  Sir you told about some logic but I didn't get that so can you explain briefly..??
Message 34 of 41
(1,807 Views)
Hi Gowtham,
what about ElapsedTime don't you understand?
Message 35 of 41
(1,800 Views)
Hello GerdW sir,
Do I need separate while loop for  that time elapsed..?? and what is that wait time value 123..??
Message 36 of 41
(1,772 Views)
Gowtham,
     Are you serious about learning LabVIEW?  Have you tried to duplicate the (very simple) code that GerdW showed you?  Have you looked at the Help on the functions to figure out for yourself what they are supposed to do?  Have you run the code and seen what happens?  Have you made an intelligent guess what is happening?  Have you figured our a simple test you could do (hint -- it involves "123") to "test your hypothesis" (hypothesis = fancy term for "guess")?
     Put a tiny bit of effort into doing this yourself, please.
Bob Schor
P.S. -- I apologize in advance for the tone of this post.  If we do your classwork for you, you will learn nothing.  How will you be able to succeed on your own in the Real World?
Message 37 of 41
(1,770 Views)
Hello Sir
Thank you sir , I tried the code when I run vi  and click Play Music button the Elapsed time works properly but when I again run my vi next time the Elapsed Time Display shows the previous value and when I press Play Music button it Restart  Time Elapsed value and works properly but how to clear the previous value when I run the vi each time..??even though I set Automatic Reset Enable.
Message 38 of 41
(1,766 Views)
Hello Bob_Schor Sir,
Yes sir I surely want to learn LabVIEW. But I was little Confuse about that, only because of that I asked too many questions I apologize for my mistake.
And Sir u don't need to be Apologize because u told that me to learn for my Knowledge  and surely ill take it in a positively
Message 39 of 41
(1,764 Views)
Hi Gowtham,
It's been a while you have posted "your VI".
So how should we comment on the current state of "your VI" and the problems you have with "your VI"?
No code, no comments…
Message 40 of 41
(1,753 Views)
