Agilent 34401A multimeter to PC with Labview driver via RS232
Please Kudo those responses that helped you and Mark one as the solution in order to close out this thread.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
Message 41 of 58
(2,087 Views)
Hi All,
When I am connecting a Agilent 34401A DMM using RS-232 to USB converter cable , I am unable to find new visa port,com port or gpib port in NI-MAX for this machine. How can I sort this out
thanks and regards
Ashish
Message 42 of 58
(2,084 Views)
Hii All,
Now I am connecting the Agilent 34401A, with RS-232 -USB cable, In NI-MAX, I am getting new port option now as COM7. . When I am during ID query or when I am running read measurement file of Agilent 34401a I am getting some error. I am attaching both errors of ID query and .vi running error . Can any one help whats the problem in it. I have double checked Baud rate, Parity and Data Bits and put that same in NI - MAX, 344401A, and in .vi file which I am running.
Message 43 of 58
(2,070 Views)
Attachments are missing.
Message 44 of 58
(2,067 Views)
Oh Sorry,
the attachments are here.
Thanks and Regards
Ashish
Message 45 of 58
(2,051 Views)
Are you sure the device will respond to that query?
Are you sure you have the right cable?  Serial port settings such as baud rate, data bits, stop bits?
Does the device need a button pressed on it to put it into "remote mode" instead of "local mode"?
Message 46 of 58
(2,044 Views)
Yes, the device is responding the query but with a error as shown in above attachment. Yes all data is fine as well as remote mode as well.
Ashish
Message 47 of 58
(2,034 Views)
Ashish
Actually the instrument is NOT responding to the query.  The error is LabVIEW telling you that it timed out before a response was received.
One thing you didn't mention - are you sure that the instrument is on COM7???  I see a COM6 in your picture as well.
Bill
CLD
(Mid-Level minion.)
Message 48 of 58
(2,010 Views)
Yes I am sure its  Profilic USB to serial COMM port. and COM6 is  Intel(R) Active Management Technology - SOL
any more suggestions are welcome to solve this
Thanks and Regards
Ashish
Message 49 of 58
(2,001 Views)
The image that you sent earlier showing the timeout was on COM7 not COM6.  Does the instrument respond when you do an ID query on COM6?
Message 50 of 58
(1,994 Views)
