Appear one display at a time.
I have two sensors analog and digital and they are connected through a com port by using VISA (one at a time) in labview I have two display one for analog and one for digital. My question now how can I display one at a time ! For example when plug analog sensor I want the only display of analog appear to the user and via versa. Is that possible ! Any idea!
Regards
Message 1 of 8
(4,228 Views)
And what's the problem?
if you want to hide one of the indicators, use the property -> visible
Message 2 of 8
(4,202 Views)
Care to give more details about what you are connecting to the serial port?  I imagine they have different messaging protocols.  So you just need to figure out which protocol is being used and update the values that correspond to the received data.
GCentral
Message 3 of 8
(4,199 Views)
Thank you for your response.
The idea here I have two sensors, the analog sensor send "A" as initial value and the real data, also when I disconnect the analog sensor and connect the digital sensor into com port it will send "D" and then real data.
All works fine but what I mean that I want one VI for display both analog and digital data but when I plug any sensor and run the VI, I want just one display appear corresponding to the sensor that attached in the port. I don't want when I run the VI, both display appear and one of them is working corresponding to the sensor and the other one is just plain and nothing on it?
Message 4 of 8
(4,191 Views)
As I have two displies in one VI, one for analog sensor and the other for digital sensor. I want one display appear to the user corresponding into the port.
Regards
Message 5 of 8
(4,190 Views)
Here are some options:
1. Use 2 VIs.  It only makes sense to have a VI for each sensor.  This greatly reduces complexity and is very simple.
2. Use a subpanel.  Sort of back to #1, but the idea is that when you read the first data, you know which GUI to load into the panel.
GCentral
Message 6 of 8
(4,188 Views)
Thank you very much crossrulz for your replay.
The first option is straight and easy to implement but I want one VI.
The second option I will look at it and if you have example or any similar vi can you please share it.
Regards
Message 7 of 8
(4,180 Views)
Maybe you can have a "tab control" with two tabs and Hide the not used page using property node.
Message 8 of 8
(4,115 Views)
