Array constant grey entry
Say I have a array constant with 3 elements
I want to delete the 3rd element and grey it out, so it look like this
Can't seem to find a good way to do this other than remake the entire array. It is fine when the array only has a few elements, but when it is an array of shared variable reference of 50, it takes some time.
(4,540 Views)
Did you try to rightclick the element and delete?
(4,533 Views)
Accepted by rhong
Specifically, RIght Click-> Data Operations -> Delete Element.
(4,530 Views)
Thanks!!
(4,523 Views)
There should really be a shortcut for that, like ctrl+delete.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(4,466 Views)
/Y
You mean something like this?
(4,462 Views)
Exactly like that. 🙂
/Y
Qestit Systems
(4,458 Views)
