Showing results forĀ
Search instead forĀ
Did you mean:Ā
Array constant grey entry
Say I have a array constant with 3 elements
I want to delete the 3rd element and grey it out, so it look like this
Can't seem to find a good way to do this other than remake the entire array. It is fine when the array only has a few elements, but when it is an array of shared variable reference of 50, it takes some time.
(4,477 Views)
Did you try to rightclick the element and delete?
(4,470 Views)
Accepted by topic author rhong
Specifically, RIght Click-> Data Operations -> Delete Element.
(4,467 Views)
Thanks!!
(4,460 Views)
There should really be a shortcut for that, like ctrl+delete.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(4,403 Views)
/Y
You mean something like this?
(4,399 Views)
Exactly like that. šŸ™‚
/Y
Qestit Systems
(4,395 Views)
