Auto Complete of tests
I am creating UI a for regular testing of valves. I need to create an option where user will select the  all th tests which he wants to do only once . Test cases should execute one by one. I am using Tab control for different test cases.
How to change the tabs after the execution of one test case. And also how to execute all the selected test cases.
Please help. Please see the attached Vi.
Message 1 of 12
(4,011 Views)
To select the test cases, provide the user with a Listbox Ctl in the UI.
To change the tabs, wire the appropriate & corresponding selected test case value from the Listbox directly to the Tab if it is an indicator or to tis local if it is control. You need to use the Index Array function to get the single current value of the test case from the list of cases selected from the Listbox to pass to the Tab to change it.
- Partha ( CLD until Oct 2027 🙂 )
Message 2 of 12
(4,000 Views)
Accepted by kaush
I don't know if undrestand your request.
attached is an example.
Message Edité par ReG64 le 10-08-2009 04:26 AM
Reg
Message 3 of 12
(3,984 Views)
Thanks for the reply... I also did it in this way.. Anyway i thank both..
Message 4 of 12
(3,974 Views)
Can you post a snapshot of your VI?
Message 5 of 12
(3,971 Views)
And also i need to fill that listbox by reading Microsoft access file and then i should start the test. I am trying that.. Any quick solution or help ??
Thanks in advance.
Message 6 of 12
(3,970 Views)
Hello Partha,
This is the image of block diagram
Message 7 of 12
(3,969 Views)
I m sorry, I should have asked as 'UI'; I mean the FP...
Your code needs to be cleaned-up for unecessary wire bends.
Message Edited by parthabe on 10-08-2009 05:48 AM
Message 8 of 12
(3,960 Views)
Here is the front pannel.. Also Please suggest some ideas for my other question.
Thank You,
Message 9 of 12
(3,950 Views)
I think you need the DB toolkit to access MS Access from LabVIEW.
Message Edited by parthabe on 10-08-2009 06:30 AM
Message 10 of 12
(3,933 Views)
