Auto Complete of tests
kaush wrote:
Here is the front pannel..
Why is that you need a Tab in your UI? You told earlier that it is a sequence of automated test cases, which means nothing will(should) be operable on the Tab, by the user. So, why dont you provide a Table indicator similar to the one in TestStand for the user to see the results of each & every test case as & when it gets over?
Can you please explain your idea behind this thing?
- Partha ( CLD until Oct 2027 🙂 )
Message 11 of 12
(486 Views)
If the user wants to see the different test result after completion then he can use the tabs.
Message 12 of 12
(482 Views)
