‎11-17-2020 07:04 AM
Hello, my block diagram messed up by itself. All the wires are spread all around the block diagram, there are wires everywhere and i cant even delete. Additionally, some of the elements on block diagram are not seen and loops are on other loops but Surprisingly it is working.
I tried to recover from Windows Restore previous versions, Labview temp file but it didn't work.
Are there any other idea?
‎11-17-2020 07:43 AM
This is common when your block diagram gets outside of a specified range (the exact values are escaping me at the moment). Simply put: your diagram got too large. Try shrinking your diagram some and hopefully it will come back. If not, I really hope you have a backup, either in Source Code Control (preferred) or a copy, that you can revert to. Use subVIs to modularize your code is probably the easiest way to avoid this ever happening. Generally, it is best to keep a diagram limited to a single monitor screen.
‎11-17-2020 08:27 AM
By no means clear what to do. Are they wild wires those horizontal lines in the navigation window? If yes, try to go there and Clean them up.
‎11-17-2020 08:49 AM
Crossrulz may not have a very accurate 8-Ball.
I would look for Structures that have the auto-grow property disabled and sections that are excluded from Block diagram Cleanup.
As a fast rebuild take the following steps.
SUPERPRO TIP: to completely reset options close LabVIEW then rename LabVIEW. Ini
That should have solved 100% of the Structure settings and hidden code. You will need to do some work afterwards to segregate some sections of your code into appropriate subvis and learn better coding practices.
‎11-17-2020 12:47 PM - edited ‎11-17-2020 12:55 PM
(I agree that this is most likely the core of the problem)
:Autogrow disabled" does not cause wires going nowhere, whiteout sections, etc.
‎11-17-2020 11:41 PM
I am sure that the diagram in the specified range, i have much larger diagram without any problems. unfortunately there were not any backup
‎11-17-2020 11:42 PM - edited ‎11-18-2020 12:19 AM
@pincpanter wrote:
it can not be deleted, probably it is belongs to some loops when i dleete some loops it is getting deleted.
‎11-17-2020 11:46 PM
It's not the absolute size, but the coordinates of the items. You can have a small diagram that is positioned near the edge, exceeding the valid range and experience these issues.
‎11-17-2020 11:56 PM - edited ‎11-18-2020 12:18 AM
@JÞB wrote:
Autogrow is already working but i disabled and re-enabled for Fast rebuild option but didn't work.
SUPERPRO TIP also didn't work. When i tried to create snipped i am having the save screen but when i click on save button the snipped file is not creating in the specified folder.
‎11-18-2020 01:33 AM
@truskawka ha scritto:
@pincpanter wrote:it can not be deleted, probably it is belongs to some loops when i dleete some loops it is getting deleted.
Actually I suggested to Clean up (right-clicking on the wire), not to delete.
But probably this will not work.
