Can I always edit a LabVIEW program even if the device drivers are not installed on the machine being used for editing?
If I do not install the device drivers with LabVIEW can I still edit any given LabVIEW program created with that version?  Or, do I need to install the device drivers if I am editing a program which uses those drivers?
Dave
Message Edited by davey31415 on 11-09-2009 01:38 PM
(3,649 Views)
Yes you can always edit your LabVIEW code, however you cannot test/debug them since they most likely have missing subVIs, using conditional disable structure you can overcome these issues.
Ton
My LabVIEW Ideas
(3,635 Views)
Thanks.
I'm using LabVIEW 7.1 and when trying to open a program I receive the following prompt:
The program can't start because nidaq32.dll is missing from your computer.  Try reinstalling the program to fix this problem.
While I was waiting for an answer to my question I was trying to reinstall- that didn't fix it.
I'm using LV7.1 because when I try opening this program with LV8 or higher I receive many errors.  I haven't used LV7.1 for quite some time and only have disc 1 with me.
Any ideas on how I can get this DLL installed?
Dave
(3,622 Views)
Accepted by davey31415
What did you reinstall? The dll is part of the traditional DAQ driver.
(3,610 Views)
Dennis,
I had tried reinstalling LV7.1.  Now I'm installing the Legacy DAQ drivers.
Dave
(3,597 Views)
