Can i save VI front panel as a picture?
@happybird wrote:
I have ran this VI,but why it doesnt work,it appears"LABVIEW an input parameter is invalid" NI488 ,Command need GPIB controller to be controlled in charge"
ssmith's VI works just fine, You just need to make sure that all the paths are defined on the controls before running it. You get that error if you leave them blank and just hit the run buttton.
Message 11 of 12
(517 Views)
Got it! Thanks!
Message 12 of 12
(515 Views)
