Can not play wav file using labview 2016, Error code 4810
What can the reason be?
Message 1 of 17
(5,058 Views)
Hi Michael,
the reason is given in the error message - what else do you want to know?
It would help when you would attach this WAV file so we could test this feature too (or even check the WAV file format)…
Message 2 of 17
(5,047 Views)
Here is the sound file.
Message 3 of 17
(5,043 Views)
Where is it?
If you have upload problems you might put it inside a ZIP archive…
Edit:
I guess it's the default sound file coming with Windows installation.
Even Audacity yells at it:
Conclusion: Use WAV files with default uncompressed encoding with LabVIEW…
Message 4 of 17
(5,036 Views)
I'll try again. Here is the sound file.
Message 5 of 17
(5,032 Views)
Thanks 🙂
Do you have an uncompressed wav file? I would like to try.
Or is the a way to fix an conpressed file?
Message 6 of 17
(5,024 Views)
Hi Michael,
You can use Audacity to create WAV files. It's free to use…
Search for a conversion tool that handles compressed WAV files…
Message 7 of 17
(5,020 Views)
I downloaded Audacity and found that "chrimes.wav" is can be imported and played in Audacity.
My VI still don't run though...
Message 8 of 17
(5,012 Views)
Hi Michael,
I can play your file without errors using LV2011…
Message 9 of 17
(4,994 Views)
good for you 🙂
Message 10 of 17
(4,992 Views)
