01-16-2017 10:51 AM
Already had conversation with Micronoptics and didn't get a helpful answer. The device I have is si255 interrogator. On the other hand, I already went through the examples send to me regarding using the instrument via labview was without block diagram. So I see nothing regarding programming.
01-16-2017 10:58 AM
Manual looks fairly complete with commands, even has a basic LabVIEW implementation shown using TCP/IP:
http://www.micronoptics.com/download/manual-pdf/#
-AK2DM
01-16-2017 11:05 AM
I have fully analized this manual but unfortunately it doesn't consist of my device. But still I went through the similar steps as shown in the manual but unfortunately didnt work.
I just would like to ask. Did anyone of you have a chance to work with interrogator along with labview?
01-16-2017 11:25 AM
Sorry, posted wrong manual, the 255 manual has even better LabVIEW material. The is a API with source code for LabVIEW. I have not worked witht the Interrogate but have used other Micron instruments.
http://www.micronoptics.com/product/optical-sensing-instrument-si255/
-AK2DM
01-16-2017 11:35 AM
If we are talking about same source code, the block diagram is locked and invisible. If you are talking about another one, can you kindly share with me?
01-16-2017 12:05 PM
See Section 5.4 of the 2nd manual I linked to.
-AK2DM
01-16-2017 12:09 PM
I didnt see that one previously. Will check and inform you by tomorrow about the result. Thank you so much for your help!
