Connectin' FBG Interrogator via Ethernet to Labview
Already had conversation with Micronoptics and didn't get a helpful answer. The device I have is si255 interrogator. On the other hand, I already went through the examples send to me regarding using the instrument via labview was without block diagram. So I see nothing regarding programming.
Add 273 on whatever Celcius said.
-Kelvin
Message 11 of 17
(1,465 Views)
Manual looks fairly complete with commands, even has a basic LabVIEW implementation shown using TCP/IP:
http://www.micronoptics.com/download/manual-pdf/#
-AK2DM
Message 12 of 17
(1,460 Views)
I have fully analized this manual but unfortunately it doesn't consist of my device. But still I went through the similar steps as shown in the manual but unfortunately didnt work.
I just would like to ask. Did anyone of you have a chance to work with interrogator along with labview?
-Kelvin
Message 13 of 17
(1,458 Views)
Sorry, posted wrong manual, the 255 manual has even better LabVIEW material. The is a API with source code for LabVIEW. I have not worked witht the Interrogate but have used other Micron instruments.
http://www.micronoptics.com/product/optical-sensing-instrument-si255/
-AK2DM
Message 14 of 17
(1,453 Views)
If we are talking about same source code, the block diagram is locked and invisible. If you are talking about another one, can you kindly share with me?
-Kelvin
Message 15 of 17
(1,450 Views)
See Section 5.4 of the 2nd manual I linked to.
-AK2DM
Message 16 of 17
(1,442 Views)
I didnt see that one previously. Will check and inform you by tomorrow about the result. Thank you so much for your help!
-Kelvin
Message 17 of 17
(1,440 Views)
