Convert time to second and put this to an oaix of 3d graph
I have attached a screenshot which shows the 3D graph properties configuration which achieves the Date-Time format as: mm/dd/yy hh:mm:ss.  The dialog box was obtained by right clicking on the control and selecting CW Graph3D -> Properties...  I did this with the example attached by Pana-man in a previous post.
Can you post a screenshot of where you are not able to find what you are looking for?  If you don't have the same options you see in the screenshot, can you simply indicated the date in a separate indicator, and use a different time format on the plot itself, perhaps just showing the time?
The more specific you can be with screenshots and code, the better we'll be able to interpret what you're looking for, and make suggestions!
Best Regards, and I hope this is what you're looking for!
Best,
JLS
Sixclear
Message 11 of 15
(793 Views)
Hi
As i had posted here i am not having sucess in plotting time at aix X of my 3d curve graph.
Today,my frontal panel is like a doc that i am sending.
I know that i have to pass time and date to seconds and there is a interval in years between labview and 3d graph, but i need help.
Te last help i received helped me a lot,but is in labview 7 and i am using only labview 5.1.
Another doubt is: in the first time and time, i have 3 values for ach termistor,and i need to plot 1 point in graph for each termistor.And now i am having a line, and i do not want a line now.
Example:
time 1: 3 points
time 2: 3 points
and each point correspondig with temperature, time and the the termistor .
Thanks a lot and i hope that helps.
Case not,i send more information with more details.
obs:the properties of the 3d graph i know,but i need to work this..Help me please!
Rafael
Labview 5.1
Brasil
Message 12 of 15
(780 Views)
I have posted some messages but anyone has solved my problem. I hope that, now you help me, because I am in a urgency.
I am working only with labview 5.1 because is the only version available in my lab.
Let's go to the problem:
I am sending the vi and the screenshot of my frontal panel with some changes that I need to do.
I have a table which will be part of my graph.
Time will be aix X, Termistors (1 to 4) will be aix Y and Temperature from each termistor will be aix Z.
I need to plot the correct time of my table in aix x of my 3d graph time. How to do this??I have use properties of garph,I did many things and I am still in this problem. (Resume: how to write hours:minutes:seconds in aix X)
The second problem is that I need to plot in the graph only the points .Example: in time 12:00:00 I will have 3 points. Point 1 -indicating time,temperature for termistor 1. Point 2-indicating time,temperature for termistor 2 and etc. Point 3 -indicating time,temperature for termistor3. What I want is the blue points in garph. But now I have some lines and tis wrong.
Later i will do fitting for each time with the points i got.
Please help me !!
I am in hurry,I am doing my job but now I found some problems. Let's change ideas.
Thanks a lot!
Rafael
Brasil
Labview 5.1
Message 13 of 15
(772 Views)
Hi!!
I need urgently an anser more consitent with my question.
Anybody could help me please..
Thanks a lot
Rafael
Labview 5.1
Brasil
Message 14 of 15
(762 Views)
Since most of us aren't using your version, maybe you could take the axis labels of 1,2,3,4 and make a text box next to the 3D graph that lists the chart index(1,2,3,..) and the time/date. Maybe it isn't possible to solve this in your version.
Message 15 of 15
(750 Views)
