Converting csv files to signals
I need to convert this csv file to an analog signal.  The timing and magnitude need to be exact
Message 1 of 31
(6,440 Views)
Sorry my internet browser was messed up here is the file
Message 2 of 31
(6,434 Views)
So, what have you tried? You are showing an image of an Excel file so save it off as a text file and read it with the Read From Spreadsheet File.
Message 3 of 31
(6,426 Views)
I've tried alot of the signal generation options, and the simulate arbitrary signal vi, but that requires that you enter in all 100000 points.
Message 4 of 31
(6,377 Views)
That has nothing to do with your question about reading from a file and if you are talking about the express function, your statement is not even true.
Message 5 of 31
(6,366 Views)
Well I know you can load .lvm files, but how do I convert the .csv to a signal?
Message 6 of 31
(6,354 Views)
I already told you how to read the file. The essentials of a signal/waveform consists of a y array and dt value. You showed both of those in the Excel file you had. You will get a 2D array from the read so just use the Index Array functions.
Message 7 of 31
(6,349 Views)
As Dennis already stated, use the Read From Spreadsheet File VI.
GCentral
Message 8 of 31
(6,346 Views)
Yeah, I know I have to use the read spreadsheet vi, but after I read the spread sheet I have to convert the array to a signal.  I'm having trouble on finding the right signal generation vi.
Message 9 of 31
(6,337 Views)
Have you tried the build waveform?
GCentral
Message 10 of 31
(6,327 Views)
