Custom Right Click Menu
@Kilo_Watts wrote:
[...] Unless, of course, I'm just misinterpreting their instructions.
Also, didn't you get it to work once you built a menu?  How did you build that menu?
I'll guess, without reading the application note, that you did misinterpret their instructions.  Even though your topic said "Custon Right Click Menu" and you specified it in your original post, I had interpreted (after looking at your code) your intention as being to use a custom menu for the VI, not for the control.  That's what I did.  My last post used the custom menu you had provided for the control.
Jim
Message 21 of 22
(1,626 Views)
OK, now I get it.
I'll probably be able to integrate the event based solution you provided in your last post to solve the problem and I want to thank you and Hooovahh for your help in working this out.
Message 22 of 22
(1,611 Views)
