Decoding calculator
I am developing a Labview calculator to decode the HEX & Binary to decimal number by using below formula.
The decimal number I got is round to the middle of digital signal. It is possible to round the decimal number to ceiling and floor?
Thank you.
Message 1 of 8
(4,722 Views)
Can you attach some LabVIEW code so we can understand how your question relates to LabVIEW?
I don't know what you mean by "round to the middle of a digital signal."
LabVIEW has several rounding functions that round down, round up, and round to nearest.
Message 2 of 8
(4,721 Views)
I have an example:
U9.1.8
By entering the Integer and Fractional bits, my calculator is getting decimal number of 0.78125. However, if i am using others tool, the result is 0.77902.
I am not sure can I get the exact decimal number or not.
Message 3 of 8
(4,702 Views)
Your latest post made things even less clear.  What is "U9.1.8"?  How does any of this relate to the digital signal you showed in the first post?
Message 4 of 8
(4,697 Views)
U9.1.8
U = Unsigned
9 = Total bits
1 = Integer bits
8 = Fractional bits
The example shows decoding from the above format from HEX code (C8) to decimal number.
I am thinking whether can decode the decimal number to nearest to ceiling / floor number.
Message 5 of 8
(4,695 Views)
Hi Juliana,
your result seems to be correct:
Or try this:
When you want to get the next possible values of your FXP numbers you need to count up/down your input value for one LSB…
Which other tools do you use?
How do they calculate their results?
Message 6 of 8
(4,675 Views)
Hi GerdW,
Thanks for the reply.
Actually i also not too sure what tools they (other team) are using.
May i know what tool that you are using to get 0.77902?
Thanks.
Message 7 of 8
(4,667 Views)
Accepted by JulianaLee
Hi Juliana,
Why don't you ask "them" - whoever that is?
As you can see from my images I get the same value of 0.78125 as you do.
Message 8 of 8
(4,665 Views)
