Display the measurement from oscilloscope to computer screen
How can ı do that sir ?
Message 11 of 41
(2,688 Views)
Do what?  Set up the driver or manually capture the signal?
Bill
CLD
(Mid-Level minion.)
Message 12 of 41
(2,683 Views)
Can ı find the same code  ? I have been trying for a week but ı can't handle itSmiley Sad
Message 13 of 41
(2,678 Views)
What same code are you talking about? You've already found one example and where to look to see if there are others. There's obviously no code required to manually configure your instruments.
Message 14 of 41
(2,672 Views)
How can ı solve the problem sir ?
Message 15 of 41
(2,668 Views)
Please don't simply repeat your question. If you haven't manually configured the scope to acquire and actually captured a signal, you are just wasting time - ours and yours.
Message 16 of 41
(2,662 Views)
You are right. I don't understand what can ı do but ı will try it more
Message 17 of 41
(2,654 Views)
I strongly suggest you find someone who knows how to use the O-scope.  That will get you light years beyond where you are now.
Bill
CLD
(Mid-Level minion.)
Message 18 of 41
(2,650 Views)
Find a fellow student. One that's in an electronics program will almost certainly have used these basic instruments.
Message 19 of 41
(2,644 Views)
Is that common problem ?
Message 20 of 41
(2,635 Views)
