Display the measurement from oscilloscope to computer screen
@prof.Anil wrote:
Is that common problem ?
Is what a common problem?  The error?  It is if you don't know how to use the equipment you're trying to control.
Bill
CLD
(Mid-Level minion.)
Message 21 of 41
(3,011 Views)
Is what a common problem? The timeout is if you don't configure the instruments correctly. Some basic knowledge is required before you do anything with instrumentation.
Message 22 of 41
(3,008 Views)
Rule #1 of instrument control: Know how you do what you are trying to do using the buttons and knobs of the instrument manually.  Once you have that figured out, you can start writing a program to mimic exactly what you did manually.  If you do not understand how to work the instrument manually, you'll never figure it out programatically.
So if you do not understand how to work the oscilloscope, go find somebody who does and have them teach you how to use it.
Message 23 of 41
(3,001 Views)
Thak you for your attention.
Message 24 of 41
(2,998 Views)
You are right sir.
Message 25 of 41
(2,995 Views)
Check out this topic:  http://forums.ni.com/t5/LabVIEW/instrument-control/m-p/3134112#M901103
Just connect your USB cable to the scope and use Help > Find Instrument Drivers...  LabVIEW will find your scope and download everything you need including a new palette of Agilent VIs and examples.  It takes only a few minutes.  Don't make it more complicated than it needs to be.
Message 26 of 41
(2,990 Views)
Well, technically YES.  A timeout error is a very general problem that means you're not communication with the scope.  There could be many reasons why.  The firs thing to do is see if your scope shows up in NI MAX (Measurement and Automation Explorer).  Click on Devices and Interfaces and tell us if you see your DSO.  If NOT, you must fix the problem before you go any further...
Message 27 of 41
(2,980 Views)
It is one of the examples that is throwing the error and an instrument not listed in MAX will cause a completely different error.
Message 28 of 41
(2,973 Views)
Yes ı see.
Message 29 of 41
(2,970 Views)
Then open this most simple example:  Help > Find Examples >
Message 30 of 41
(2,953 Views)
