Display the measurement from oscilloscope to computer screen
You should now be able to select your VISA resource name.  Then, press the RUN arrow and it should talk to your scope and read the waveform.
Message 31 of 41
(3,013 Views)
Same ProblemSmiley Frustrated
Message 32 of 41
(3,007 Views)
Thank you for your attention.
Message 33 of 41
(3,002 Views)
Next step is to open the block diagram of the example to see how it works so you can expand on it if you need.  Generally, when you talk to hardware with LabVIEW you go through the same basic steps.  1) Initialize the hardware and establish communication protocol  2) Configure the hardware so it does what you need  3) Trigger the hardware to collect data [Optional - some hardware just collects all the time]  4) Read the data it collected  5) Close the resource.
I added some extra notes to the example:
Message 34 of 41
(2,998 Views)
What is the name of the example you are running?  Did you select your Scope's VISA name correctly???
EDIT:  Also try turning off your scope and turning it back on to make sure it's not in some error state.
Message 35 of 41
(2,995 Views)
Eror is :3.PNG
Message 36 of 41
(2,981 Views)
What is the scope sir ?
Message 37 of 41
(2,978 Views)
@Dennis_Knutson wrote:
It is one of the examples that is throwing the error and an instrument not listed in MAX will cause a completely different error.
Yeah, I got a bit ahead of myself there and didn't read through the thread and look up errors before I typed.  Smiley Embarassed
Message 38 of 41
(2,973 Views)
The Scope is the oscilloscope you have connected to your computer.  The Agilent DSO-X with all the buttons and knobs. Smiley Wink
Can you expand the VISA control to the right and tell me the whole resource name.  It doesn't look correct.
You're SELECTING it by clicking on the VISA Resource Name control right???  Don't type in the box, click on the control and select from the name(s) that pop-up for you.  It should start with USB0::
EDIT:  You will need to use the finger tool and click the little arrow on the far right of the control.  Get the finger tool by View > Tool Palette   then click the pointing finger.
Message 39 of 41
(2,970 Views)
VISA  resource name is right sir. I change the name from NIMAX. I am sure it is right. Smiley Sad
Message 40 of 41
(2,957 Views)
