Does anyone know how to compare 2 tables of codes?
Hi i would like to know if anyone is able to help me solve the problem i have on hand.
The idea is compare the values on the table to stimulate the robot being in an environment. I have added 2 files that are robot and environment binary codes. When running the code, please select the delimited text file first before the excel file.
Pls i am in dire need of help
Message 1 of 12
(3,464 Views)
Transferring Binary or environment excel data to labview (Subvi) is missing.
CLD Using LabVIEW since 2013
Message 2 of 12
(3,429 Views)
Oh sorry, knew i missed something out. Here, and thanks for looking at it for me.
Message 3 of 12
(3,421 Views)
You also missed the sub vi inside the this vi. Open SV Excel.vi.....
Message 4 of 12
(3,415 Views)
hmm? cant be i have given all the subvis i used in the original post tho. but just in case ill post the whole folder
Message 5 of 12
(3,411 Views)
can you tell me the simulation process?
Message 6 of 12
(3,376 Views)
hi, sorry for the late reply, as i understand it, the process is that there are 2 different binary codes that must be processed into 1 single binary code. the second step is to stimulate the robot moving through the environment in that one binary code
Message 7 of 12
(3,334 Views)
What exactly do you mean?  Process how?  What is "stimulate"?
What is a "binary code"?
Message 8 of 12
(3,328 Views)
basically combine the 2 excels attached above. the binary code is the content of the excel files above
Message 9 of 12
(3,307 Views)
You didn't attach any Excel files.
Message 10 of 12
(3,300 Views)
