Downconvert VI Requests
Please convert to 8.6 🙂
source LabVIEW version 10.0
target LabVIEW version    8.6
Message 601 of 1,444
(1,598 Views)
Hey Ajjones,
One way you can actually do this to open it up in LabVIEW 8.6 is choose Save As Previous Version in LabVIEW 2010.
If you go: File»Save for Previous Version» Drop down menu (8.6) this will let you save it as a 8.6 file
Ricky
Applications Engineer
Message 602 of 1,444
(1,538 Views)
              i am getting "memory full" error when i try to run the VI file. so any one could please help me out what is the problem, is the problem in labview memory or main memory .Thanks in advance.
paleti.
Message 603 of 1,444
(1,527 Views)
@sunflower2772 wrote:
Downconvert from Labview 9 to 8.6 please, extra kudos, extra kudos! Smiley Very Happy
SEE ATTACHED
Message 604 of 1,444
(1,511 Views)
Message 605 of 1,444
(1,510 Views)
paleti.
Paleti,
As I already suggested, please post a new thread with the issue you are having.  This thread is to downconvert VIs, only.  No other discussions.
Message 606 of 1,444
(1,507 Views)
You had many missing items for Untitled 5.vi.  Not sure if it will help.
See attached for both converted VI's.
Message 607 of 1,444
(1,505 Views)
could someone please downconvert this LabView File to version 8.5
I think the file is made with version 9.
Thank You very much!
Message 608 of 1,444
(1,493 Views)
Hi Lunzerino,
it was made using LV8.6! Now as LV8.5...
Message 609 of 1,444
(1,487 Views)
You the best Ray! Smiley Very Happy
Please PM if you didn't receive 2 kudos! Smiley Very Happy
Message 610 of 1,444
(1,474 Views)
