Downconvert VI Requests
Anyone may pls downconvert this LV 9 version to LV 8.6.
Message 831 of 1,444
(2,203 Views)
matej,
You are missing several sub-vi's in Sealing.
Also a note about both VI's.  There is a better way to write Mean.
Sealing may be very prone to race conditions.  I did not go into the code in details, but all those loops and Local Variables form a bad mix.
Here they are in LV8.0 in their original form.
Message 832 of 1,444
(2,197 Views)
Intelligent,
Here it is in LV8.6
A recommendation is to put a while loop around the Bytes at Serial Port and Serial port read.  That is to make sure that you read everything in the port.  It has a static delay of 1 sec which is poor coding practice..
Message 833 of 1,444
(2,196 Views)
Hey Ray!
Im kind of new in this. Just started with my engineering work and starting to learn programing in Labview. It's my friend's VI. Ill consider all your advices when I get to some higher level!  Thank u very much!!
greetings from Slovenia,
Matej
Message 834 of 1,444
(2,188 Views)
Matej,
If you run into strange behavior with the code, you can always post a question in a new thread and we can provide additional advice.
To learn more about LabVIEW, I suggest you try looking at some of these tutorials.
Message 835 of 1,444
(2,179 Views)
Ill have a look at this,
Than you very much for all your help!
Matej
Message 836 of 1,444
(2,169 Views)
Could I please get the following vi converted from 10.0 to 8.5?
I would be eternally greatful.
Message 837 of 1,444
(2,163 Views)
Here is LV8.5
Message 838 of 1,444
(2,160 Views)
Thanks a million man
Message 839 of 1,444
(2,155 Views)
Please could someone downconvert the files attached to LabView 7.1?
Thank you
Sincerely
Julia
Message 840 of 1,444
(2,141 Views)
