Downconvert VI Requests
@juli-tud wrote:
Please could someone downconvert the files attached to LabView 7.1?
Thank you
Sincerely
Julia
Your previous post said that the last conversion "did not work". What exactly "did not work"? What does "did not work" mean? Did you get an error dialog from LabVIEW? Was it saved in the wrong version? Were there files missing?
If it gets re-downconverted without knowing what the issue was, the likelihood of repeating the problem is pretty high...
Message 841 of 1,444
(1,949 Views)
Can someone please downconvert the attached file from its current form in Labview 8.5 to Labview 7.1 please?
Thanks!
Message 842 of 1,444
(1,948 Views)
@chatferal wrote:
Bonjour,
d'abord pardon de m'être trompé, (upconvert, downconvert...) c'est la 1ere fois que j'écris sur un forum.
Je voudrais savoir s'il est possible de convertir le vi en pièce jointe(je n'ai pas pu mettre la DLL fournie avec)
qui est en version 8 (je ne sais pas laquelle), dans la version 6I. C'est  un vi pour gérer la carte d'interface I/O
-USB k8055d de Welleman.
Je sais que la version de LABVIEW 6i est un ancêtre, mais j'ai beaucoup travaillé avec, et...je l'ai, en cadeau(chut).
Merci.
attached
Message 843 of 1,444
(1,944 Views)
Thanks!
attached..
Message 844 of 1,444
(1,940 Views)
The last down conversion did not quiet work. I am receiving the error code 9: Vi version (8.5) is newer than LabView version (7.1). Please could someone downconvert my files again?
Thank you very much,
Sincerely,
Julia
Message 845 of 1,444
(1,936 Views)
Sincerely,
Julia
Attached is in 7.1. You will need to do some code cleanup since some of the File I/O functions are different between 7.1 and 8.5. Also, you will need to create the string version of the Read From Spreadsheet File. Open the Read From Spreadsheet File VI that exists in 7.1 and look at the block diagram. It contains instructions on how to create a string-based version. Be sure you make a COPY, and do not save the copy in the vi.lib folder. Save it in your own folder.
Message 846 of 1,444
(1,931 Views)
Thank you for the support!
Sincerely,
Karl Coppini
@smercurio_fc wrote:
Thanks!
attached..
Message 847 of 1,444
(1,920 Views)
Bonjour,
Pour développer une application avec un modem GSM j'ai besoin de la librairie Modbus TCP de la version 7.0 de Labview pour communiquer entre un Fieldpoint 2000 et un modem GSM/GPRS. J'ai cherché sur le net mais je ne trouve pas la librairie pour cette version. Etant donné donné que c'est un protocole très utilisé et pas si récent je pense qu'il doit y avoir chez NI une archive avec cette librairie.
Merci pour votre aide
nom du fichier à convertir : nimodbus121.zip
Arnaud
Message 848 of 1,444
(1,913 Views)
Please convert this Labview 2009 to Labview 8.2
Thanks,Branson
Message 849 of 1,444
(1,902 Views)
Thanks,Branson
attached
Message 850 of 1,444
(1,896 Views)
