Downconvert VI Requests
Hi !
Can someone please, downconvert the attached file from its current form to Labview 8.5 ?
Thank you so much
Message 851 of 1,444
(1,831 Views)
Here it is
Message 852 of 1,444
(1,823 Views)
Could someone please downconvert the following two folders to Labview 7.0?
Nlabv_neo.zip is in Labview 9
sm32_v2_35_lv82.zip is in Labview 8.2.1
Thanks in advance,
Karl
Message 853 of 1,444
(1,813 Views)
Could you convert this file to 8.6?
Thanks.
Message 854 of 1,444
(1,797 Views)
Here is LV 8.6.  It calls for a subVI that you didn't include.  So you will need to relink the VI to that, and possibly have that downconverted if you don't have it in LV8.6 already.
Message 855 of 1,444
(1,789 Views)
Could someone please downconvert the attached zip file to labview 7.1?
The current version is Labview 8.5.
Thanks!
Karl
Message 856 of 1,444
(1,771 Views)
Can somebody downconvert the attached vi and the three subvi's to 9.0, please?
They are currently v10.0.
Thank you!
Message 857 of 1,444
(1,761 Views)
try the attached
Message 858 of 1,444
(1,752 Views)
Thanks!
Karl
attached
WARNING: As with the other conversion, you may need to go into each VI that calls the DLL and fix the Call Library Function Node in regards to the path that's used for the DLL. If the DLL is in the C:\Windows\system32 directory, then only the name of the DLL should be in the Call Library Function Node's path specification.
Message 859 of 1,444
(1,750 Views)
attached.
Warning: This is poorly written code. The writer must have had a 30" monitor, and assumed that clearly everyone else had one as well. There is also no error handling to speak of.
Message 860 of 1,444
(1,745 Views)
