04-21-2011 03:13 AM
Anyone may pls downconvert this LV 9 version to LV 8.6.
04-21-2011 07:27 AM
matej,
You are missing several sub-vi's in Sealing.
Also a note about both VI's. There is a better way to write Mean.
Sealing may be very prone to race conditions. I did not go into the code in details, but all those loops and Local Variables form a bad mix.
Here they are in LV8.0 in their original form.
04-21-2011 07:31 AM
Intelligent,
Here it is in LV8.6
A recommendation is to put a while loop around the Bytes at Serial Port and Serial port read. That is to make sure that you read everything in the port. It has a static delay of 1 sec which is poor coding practice..
04-21-2011 07:51 AM
Hey Ray!
Im kind of new in this. Just started with my engineering work and starting to learn programing in Labview. It's my friend's VI. Ill consider all your advices when I get to some higher level! Thank u very much!!
greetings from Slovenia,
Matej
04-21-2011 10:21 AM
Matej,
If you run into strange behavior with the code, you can always post a question in a new thread and we can provide additional advice.
To learn more about LabVIEW, I suggest you try looking at some of these tutorials.
04-22-2011 02:22 AM
Ill have a look at this,
Than you very much for all your help!
Matej
04-22-2011 12:20 PM - edited 04-22-2011 12:22 PM
Could I please get the following vi converted from 10.0 to 8.5?
I would be eternally greatful.
04-22-2011 12:29 PM
Here is LV8.5
04-22-2011 01:10 PM
Thanks a million man
04-23-2011 06:50 AM
Please could someone downconvert the files attached to LabView 7.1?
Thank you
Sincerely
Julia
