Downconvert VI Requests
Is there any reason you want to take it back to 6.0 considering you have a whole slew of newer versions?
As S_Mercurio said, very few people have 6.1.  My oldest version is 7.1.
It might be best if you just opened it up in a version that you have and just code it from scratch in 6.0.
There is a problem with your VI that will cause problems for anyone who tries to help you.  You have it password protected!
Message Edited by Ravens Fan on 04-05-2010 03:09 PM
Message 61 of 1,444
(5,163 Views)
Sorry about the password.  I thought I got it to 6.1 without having to enter the password, so I figured it was not needed to convert.
I will probably end up doing what you recommend.
Message 62 of 1,444
(5,158 Views)
could you downgrade from Labview 8.5 to Labview7.0 this project:
thanks,
Alexandre
Message 63 of 1,444
(5,137 Views)
thanks,
Alexandre
AttachmentS7Com_2009_11_06.zip (161 kb)
AttachmentSiemens S7 TCP v3_3 LV 8_5.zip (302 kb)
Message 64 of 1,444
(5,109 Views)
Please be patient. What you're asking for is not simple, and this board is primarily made up of volunteers, most of whom (like me) have full-time jobs.
thanks,
Alexandre
Attached is in 7.0, but there are several issues:
  • The VI "S7Com_WRT_READ(subVI)" (why did they use "subVI" in the name???) uses a Feedback Node, which doesn't exist in 7.0.
  • The VI "S7_Optimize_Read_Array" used the conditional stop on the for loop, ,which doesn't exist in 7.0.
  • Projects or lvlibs did not exist in 7.0, so I created an "untitled" VI for each to place all VIs and controls in order to backsave.
Message Edited by smercurio_fc on 04-07-2010 10:04 AM
Message 65 of 1,444
(5,106 Views)
Could someone please down convert the following Labview 8.5 files to Labview 8.2.1?     Or  let me know how to do it myself.
Thank you
Message 66 of 1,444
(5,100 Views)
Attached should be in 8.2.
Message 67 of 1,444
(5,094 Views)
Thanks for the quick response.  The only problem is that my Labview 8.2 only opens 1 of the files.  The following file I get a "memory or data structure corrupt" error.
Generalized FT Filter.vi
Message 68 of 1,444
(5,088 Views)
Hi Dan,
it opens fine for me - but I don't have IMAQ or VISION installed...
Message 69 of 1,444
(5,085 Views)
hmm - I get a different error trying to load this time.    I attached a pic of error.
I really appreciate the response time of this forum!
Message 70 of 1,444
(5,064 Views)
