Draw a circle and its center..
Please suggest a vi that can represent a circle and its center as two plots in a graph
Message 1 of 13
(2,865 Views)
try  generate 2 sinusoid functions, shifted of 90 degress on phase, and bundle to plot on  XY graph
Message 2 of 13
(2,838 Views)
here's a rube goldberg-ish version by  using labviews built in "plot circle by radius", complex numberes, build cluster array and a XY Graph
note: by updating the radius, the pixel center is set to center_x = center_y = radius
Message 3 of 13
(2,821 Views)
Accepted by topic author junnyy
Since we're doing homework now, here's my entry:
Spoiler
And my actual entry for the "postage stamp challenge":
EDIT: This might be a little smaller:
Message 4 of 13
(2,810 Views)
It wa helpful to me
Thank you!!
Message 5 of 13
(2,765 Views)
@BertMcMahan wrote:
Since we're doing homework now ...
for the sake of christmas 😉
Message 6 of 13
(2,707 Views)
I'm deducting 1 point from your homework grade for not plotting the center 😆
Message 7 of 13
(2,690 Views)
@BertMcMahan wrote:
From the bag of Altenbach 😉
Kudos
Message 8 of 13
(2,477 Views)
@alexderjuengere wrote:
Kudos
Don't forget to wire a T into the "exclude end?" input on the ramp pattern or you will have a point at 0 and 2pi.
Message 9 of 13
(2,471 Views)
Which is required if we want to close the circle... 😄
(With the end excluded, we would have a gap)
Message 10 of 13
(2,429 Views)
