During build of exe some folder is not coming after build
I have selected destination Test.
But in when I build exe then folder between tests not coming only vi is coming and other extra folder is coming.
Message 11 of 14
(669 Views)
Accepted by topic author Poojaavi123
Only when you install the Application, The Folders will be copied to the destination folder as you map
Message 12 of 14
(657 Views)
Now I am getting folder but in exe subfolder vi are missing.
Please suggest am I doing something wrong. I am not getting AS Vi
Poojaavi123_1-1690518592940.pngPoojaavi123_2-1690518611245.pngPoojaavi123_3-1690518631492.pngPoojaavi123_4-1690518680846.png
Message 13 of 14
(632 Views)
Thanks for Your Support now my Problem has been resolved.
Message 14 of 14
(623 Views)
