Edit txt file
In C# in order to edit a line in a file i have to do as following:
1. Read content in a string array.
2. Find a line in the array I want to edit.
3. Edit the line.
4. Write updated string array into the file.
I wonder if  I have to do the same in LabView?
(5,383 Views)
with Labview, you can write a part of a file by using cursors.
Have a nice day,
V-F
(5,380 Views)
Accepted by john7
Try this example: https://decibel.ni.com/content/docs/DOC-25163
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
(5,370 Views)
Hi ramses64,
Can you be more specific about it? What is "cursors"  and how we use it?
(5,369 Views)
As an aside, in why are you reading the whole file into an array? Why not use file.readline() and file.writeline()?
_____________________________
- Cheers, Ed
(5,360 Views)
As far as i know you can not edit a line in the middle of the file. Have to read the whole file with file.readline() any way.
(5,351 Views)
You can edit parts of a file without reading the entire file. However, you can only change the characters in the file; you cannot insert new characters in the middle or delete existing characters without reading and rewriting everything past the point where you are making changes. To go to a specific location in a file, use the Set File Position function in the File IO->Advanced File Functions palette. The next read or write will start at that file position, so to make changes in the middle of a file you need only to move to the right file position and start writing, which will overwrite the existing data from that location.
(5,331 Views)
