Error 200320: Chassis SCXI 1001 - Mod 1502
Hello there.
I'm setting for first time a SCXI 1001 chassis with several modules, 3 of them 1502 with their 1314 terminal blocks. I've used this chassis before to read some temperatures and worked fine, so I'm pretty sure the problem is me.
I get this error 200320 about simultaneous sample and hold when trying to aquire strain data, but I think the configuration is fine. I'm still pretty new on LabView and have tried checking the setup both by the Data Aquisition Express module and by MAX; but I get same result.
Please help me to set this up as soon as posible, I need your knowledge.
usuario
(2,927 Views)
Hi usuario
check out this Knoledgebase article it should answer a few of your problems.
http://digital.ni.com/public.nsf/allkb/F5529A0EF8ADDA288625713400613065?OpenDocument
If you have further troubles then post back and I'll try and assist further.
best regards
Graham Green
Sr. Product Marketing Manager
National instruments
(2,925 Views)
Hi Graham,
one of my problems is that I'm too new in LabView. I haven't assisted to any courses and have to learn by myself. I just read that article before posting this question.
I still don't know exactly what exactly is a task; neither how to create channels in LabView and how to specify the aquisiton conditions, and so, I'm limited to using the DaqAssistant Express Module. I can't find where can I change this setting there.
I used to aquire using DasyLab before, and I'm still fighting to make myself to LabView.
Usuario
(2,918 Views)
I am finally able to aquire the signal from the gauge. I've taken one the LabView examples and changed it a little. But I have a new problem now. I attach the .vi.
How do I tell the system to perform the shunt calibration?
usuario
(2,888 Views)
Accepted by topic author usuario
Hi Usuario,
you can learn LabVIEW and Data Acquisition applications development as shown in next links:
http://digital.ni.com/public.nsf/allkb/7D5F60ADBFD9CDC2862572BA005DD96A?OpenDocument
http://zone.ni.com/devzone/cda/tut/p/id/2835
The latest links explains what a virtual global channel and a task are.
As regards shunt calibration, you can read the following links:
http://digital.ni.com/public.nsf/allkb/8D81F07FBCCB6DA186256BE6000691B3?OpenDocument
http://digital.ni.com/public.nsf/allkb/286AC9A8DC0B689986256C2C0064B183?OpenDocument
http://zone.ni.com/devzone/cda/tut/p/id/3642
You may want to open a new forum thread so as not to mix topics, this is my tip.
Jesus.
(2,883 Views)
