Error code -2147217900 Typo
NI,
Can you fix the typo in the error source for code -2147217900? (Occured should be occurred)
<ERR>ADO Error: 0x80040E14
Exception occured in Microsoft OLE DB Provider for ODBC Drivers: [Microsoft][ODBC SQL Server Driver][SQL Server]
CLD Certified 2014
(8,894 Views)
DrexelDragon,
I just checked into this a little closer. This problem was reported back in 2008 and examined by R&D. It is not a native LabVIEW error and therefore we cannot fix it. It is a third party error message that is simply passed along by LabVIEW. We appreciate your feedback and I wish there was more I could do to help.
Alex W.
(8,829 Views)
@ADrexelDragon wrote:
NI,
Its Microsoft's typo.  NI has no means to fix MS software products.
(8,821 Views)
Accepted by ADrexelDragon
I'm guessing this is a problem because you display the error message to the user and it doesn't look professional to have typos in the error message...
...as a workaround for this specific case, you could simply do a 'find and replace' on 'occured' with 'occurred' on the error source.
Something like this should work:
(blog)
(8,819 Views)
Thank you for the quick response. I couldn't find anything related to this error code.
I thought it was something generated by the database toolkit, not specific to Microsoft.
CLD Certified 2014
(8,800 Views)
