Exporting Vi Files to XML or some other Readable format.
Due to security reasons of my building, Vi files are not acceptable for movement between certain systems as they are a form of binary file. I was wondering if there was a LabView provided tool to export/convert Vi files to XML or some other human readable format that could then be imported/converted back into .vi.
I understand that you can get around this by taking screenshots and recreating said .vi files on the other system, but I wanted to see if there was an already existent tool from LabView.
Thank you.
Message 1 of 18
(3,076 Views)
Hi joem,
There was a very similar question last week
And there is this old resource.
Message 2 of 18
(3,052 Views)
Are these "binary" restrictions coming from a human or from some kind of security software?
I ask because usually, restrictions on "binary" files mean that they restrict files that contain direct machine code, such as .EXE files and .DLL files, which can contain viruses or other malicious code hidden inside them.  If the restriction is only meant to block that kind of code, then a VI should be fine, as a VI file is just another interpreted file, the same way a Python or Java code file is.  It may just be that you need to convince whatever person or system is checking your files that this is actually the case.
As far as I know there's no direct way to convert a VI to XML.  LabVIEW NXG (RIP) did save its files as "plaintext" but that's not helpful here.  In theory you can use VI scripting to get all GObjects in a VI and read all their properties, but I believe there are a number of properties that can't really be set by scripting so trying to use a text dump of that to recreate any VI by hand would probably be impossible.
If "taking screenshots and recreating said .vi files" is actually an option, that implies you can send image files somehow.  If so, do you know about "snippets"?   If you highlight a selection on the block diagram (i.e. everything...) you can go to the Edit menu and choose "Create VI snippet from selection", which lets you save that selection as a PNG file.  The benefit of this is that PNG files have the ability to store information in them besides just the image, which LabVIEW uses to embed information about the objects inside them, which allows you to drop a PNG created this way on a block diagram and re-create everything exactly, including non-visible things like items in frames of structures not visible on the screen at the time.
Message 3 of 18
(3,051 Views)
Unless I am mistaken, that appears to get the vi to XML but not necessarily from XML to vi afterwards. The big part here would be to get from vi to a human readable format to verify everything inside and then be able to convert that back into a vi file on the other system.
Message 4 of 18
(3,035 Views)
Hi joem,
Yes.
You can use scripting to convert a VI (block diagram) into readable text.
You can also use scripting to convert the same readable text back into the VI (block diagram)!
Btw. using PNG snippets would violate that "binary file" restriction, too. Even more so because the "G code" part is hidden inside some additional data chunks in the PNG image file…
Message 5 of 18
(3,020 Views)
Do you know of an example as to how someone else has maybe done this move from block diagram to readable text and back?
Unsure as to how that would be done to be honest.
Thank you in advance, I really appreciate it.
Message 6 of 18
(3,012 Views)
You have yet to specify the nature of the "security reasons" and how the rules are made and enforced.
Is this an automatic screening done by some sort of extremely aggressive anti-virus?  Is it some security guy in your IT department who has gone mad with rules?  Does a person need to manually read the file contents in Notepad somehow?
I mean, if all you need to do is turn the files into files that only contain "readable" characters, you could just write a very small program that converts a .vi file to Hexadecimal characters represented in ASCII, and then another program on the other side that converts them back to a .vi file later.
The way you're describing this sounds like one of three categories:
1. You are in a situation where someone has implemented some form of "security by insanity" and you're trying to figure out how to do your job despite that.
2. Someone has implemented reasonable security measures that doesn't understand LabVIEW, and you're trying to work with them to find an acceptable solution.
3. Someone has implemented reasonable security measures that doesn't understand LabVIEW, and you're trying to work around them without them knowing.
In other words, I think you're presenting us with the "Y" in an "XY" problem.  Description here:
  • User wants to do X.
  • User doesn't know how to do X, but thinks they can fumble their way to a solution if they can just manage to do Y.
  • User doesn't know how to do Y either.
  • User asks for help with Y.
  • Others try to help user with Y, but are confused because Y seems like a strange problem to want to solve.
  • After much interaction and wasted time, it finally becomes clear that the user really wants help with X, and that Y wasn't even a suitable solution for X.
Y is your "convert a VI to XML" problem.  Tell us what "X" is.
Message 7 of 18
(2,982 Views)
There is software out there that will convert any file into a hex file and back again.  I suggest using something like that.
Message 8 of 18
(2,977 Views)
@GerdW wrote:
Hi joem,
Yes.
Sure, but it can get really tricky when you bump into things like Express VIs and XNodes.
Message 9 of 18
(2,974 Views)
@paul_a_cardinale wrote:
@GerdW wrote:
Hi joem,
Yes.
That's just one part where it get's really hard.
Some things are simply not accessible with scripting. The scripting API is simply not complete. It's been added as a curtesy\afterthought, but it's never been and probably never will be a complete API to access everything in a VI.
If you want the diagram and panel as XML, you're better off looking into LabVIEW's build in XML storage format (use NED look for the "heap save format"). That will save both heaps as compressed XML. It will still get you only 90% (maybe) of the VI. You'd have to get the rest from parsing the VI's other binary data, but that won't be XML nor documented.
If you feel like wasting a significant amount of time, but want to save some of it, you might want to start with GitHub - marcpage/pylavi: Python LabVIEW resource file parser
Message 10 of 18
(2,816 Views)
