File transfer over satellite via RS-232 modem on a Compact Fieldpoint
Hello all.
New community member here 🙂
I am building a data logger for remote applications and have a requirement to send the log file (csv format) over a satellite modem to a PC at predetermined intervals.
Basically, I was wondering if there is an easy way to go about this considering that the sat modem uses SLIP and I can't find a protocol driver for the cFP.
I can use AT commands to dial using VISA no problem.
Anyone got any ideas?
Cheers,
Ash.
(2,873 Views)
Hi Ash,
I'm not sure this is a problem because of FieldPoint. Instead, I would focus on the ability to communicate with SLIP compliant device in the LabVIEW Development Environment. Have you seen KnowledgeBase What is SLIP and How Do I Communicate With SLIP Compliant Devices Using NI-VISA? All information in this document should be readily translatable to FieldPoint programming.
Cheers.
| Michael K | Project Manager | LabVIEW R&D | National Instruments |
(2,859 Views)
Ah thankyou for that. It's exactly what I needed 🙂
Cheers,
Ash.
(2,834 Views)
